Replacing CK20S light switch ?
/ Replacing CK20S light switch ? #1
Slackdaddy
Gold Member
Land of the Free
Kioti CK20HST
My 2005 CK20S headlights, tail lights don't work, only the right turn signal works. Both rear flashers do work.
I am guessing the Light Sw is bad?
How do you remove/replace this switch, did a forum search and not finding it.
Thanks,
Nick
/ Replacing CK20S light switch ? #2
My CK20 is older than yours, but based on what I have seen on it you will need to remove the dash or at least the cover plate below the dash. Michigan Iron may have an exploded view of the dash in it's parts catalog that might help.
Cheers
Rancho
/ Replacing CK20S light switch ? #3
From memory the wiring goes underneath to the rear. Just check your connectors before pulling the switch out.
/ Replacing CK20S light switch ? #4
I would suspect fuse or corroded or broken wire before switch. I sure wouldn't order one before diagnosing the problem first. The chances of it being the switch are very low.
2005 International 4300 55' Bucket Truck (A62613)
2005 International...
2000 International 4900 Tandem Truck (A66285)
2000 International...
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
Caterpillar D6N XL Crawler Dozer (A65579)
Caterpillar D6N XL...
2022 EZ-GO ELITE...
Kohler Gasoline Air Compressor (A64553)
Kohler Gasoline...
