Replacing Chinese Fluids
/ Replacing Chinese Fluids #11
</font><font color="blue" class="small">( Does anyone think a GL-5/MT-1 gear oil is not ok for use with yellow metal )</font>
Did you check out my link to the pennzoil 80w90 gl-4 gearplus lubes?
Soundguy
/ Replacing Chinese Fluids #13
I see why the link didn't work.. that was a link to load the pdf off a server.. try this link to the title page on their gear plus page. Mid way down the page you will see a link to a pdf file.. it says this:
"""For more technical data, see product data sheets. """
This PDF that loads up is for the gl-4 gear plus lube.
I'm not sure what you read.. but in plain english, in the first paragraph, it clearly states that it is bronze safe.
I have added red lettering and italics to the section that says this.. ( if I did it right.. ).
Soundguy
Pennziol Gearplus
Here's a plain text version:
GEARPLUS® SAE 80W-90 GL-4 A Specialty Gear Oil For Applications Requiring GL-4 Performance PRODUCT DESCRIPTION PENNZOIL® GEARPLUS® SAE 80W-90 GL-4 GEAR LUBRICANT is specially formulated to meet the unique requirements of API GL-4 service in manual transmissions and transaxles of passenger cars, light trucks and SUV’s. PENNZOIL® GEARPLUS® SAE 80W-90 GL-4 GEAR LUBRICANT is blended from select base stocks and additives that yield a lubricant of exacting quality. This product is compounded utilizing specialized extreme pressure chemistry that provides protection of gears and bearings <font color="red"> </font> without being corrosive to bronze components <font color="black"> </font> . It contains foam suppressants to prevent wear, which can be caused by lubricant foaming and aeration. Effective rust and corrosion inhibitors protect metal surfaces from the effects of water contamination from condensation and the operating environment. PENNZOIL® GEARPLUS® SAE 80W-90 GL-4 GEAR LUBRICANT resists the formation of varnish deposits on synchronizer components, thus assuring long, trouble-free operation. PENNZOIL® GEARPLUS® SAE 80W-90 GL-4 gives the full protection of an SAE 90 under hard driving conditions while providing the flow characteristics of SAE 80W that are necessary during cold weather start-ups. This offers maximum lubrication and gear protection over a wide temperature range. APPLICATION PENNZOIL® GEARPLUS® SAE 80W-90 GL-4 GEAR LUBRICANT is designed for manual transmissions and transaxles of both American and import vehicles. It is formulated to be compatible with “yellow metals”, such as bronze, found in synchronizers and other transmission componenets. BENEFITS • Meets the performance requirements of API GL-4 Service • Will not cause glazing of synchronizer components • Excellent thermal stability • Outstanding extreme pressure and antiwear protection • Prevents rust and corrosion • Inhibits foaming and aeration • September, 2004 Stock # 17922
TYPICAL PHYSICAL AND CHEMICAL PROPERTIES PENNZOIL® GEARPLUS® SAE 80W-90 GL-4 TEST METHOD TYPICAL RESULTS SAE Grade 80W-90 API Service GL-4 Gravity, °API ASTM D-287 27 Flash Point, °C(°F) ASTM D-92 210(410) Viscosity ASTM D-2161 & D-445 @210°F, SUS 76 @100°F, SUS 737 @ 40°C, cSt 159 @l00°C, cSt 14.5 Viscosity Index ASTM D-2270 93 Color ASTM D-1500 5.5 Pour Point, °C(°F) ASTM D-97 -26(-15) Low Temperature Viscosity, cP @ °C ASTM D-2983 <150,000 @ -26 Material Number 12/1 Quart 21176 35 Pound Plastic Pail 4804 120 Pound Drum 4805 400 Pond Drum 4806
/ Replacing Chinese Fluids #14
</font><font color="blue" class="small">( This product is compounded utilizing specialized extreme pressure chemistry that provides protection of gears and bearings without being corrosive to bronze components )</font>
Ok.. italics worked but not red lettering.. here is the pertinant sentence.
Soundguy
/ Replacing Chinese Fluids #15
Soundguy,
I did not go to the tech data as I should have done.
Went to one of the main suppliers of the farmers around here and found a GL-1 oil but the label says nothing about yellow metal. When I asked for additional information he looked at me like I was crazy and said he had never heard of a problem with GL-5.
Wal-Marts brand GL-5 oil says it is safe and Sta-Lube's GL-4 gear oil label says "Not corrosive to copper, bronze or other non-ferrous alloy bearings and bushings". The technicial people at CRC never told me this when I called them.
Here is some more information on the subject which says service life can be cut in half using some GL-5 gear oils.
http://gravelyinfo.com/book/print/866
I have no intention of starting a second career; I just want to play with my tractor! Bought some more kerosene and will dump the GL-5 gear oil and replace it with Sta-Lube's GL-4 gear oil where the label says it is safe.
/ Replacing Chinese Fluids #16
Yep.. if you look around.. you can find a handfull of gl-4 and gl-5 products that are yellow metal safe. The vast majority do not claim this though.
Gl-1 will be safe as well...
good luck
Soundguy
2017 Mahindra 1526 (A60462)
2017 Mahindra 1526...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
INSPECTION (A61165)
INSPECTION (A61165)
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
