Replacing Brakes on B8200
/ Replacing Brakes on B8200 #1
AndyF
Central NY
Kubota B8200 & B7200
I have an older B8200, probably early '80's which needs new brakes. I've reached the end of the adjustment range and it sounds like metal to metal when I use the brakes. How straightforward is brake repair on this tractor? I've done brakes on cars, but never on a tractor.
/ Replacing Brakes on B8200 #2
Don't you have wet brakes? They are more like a clutch on a
motorcycle than brakes you have had on any car.
If you decide to pull apart your rear axle to replace them, let
us know how it goes. I have never had to replace wet brakes
myself before. They are "lifetime" items for the most part.
/ Replacing Brakes on B8200 #3
The B8200 has dry brakes. Unless the shaft seal has started leaking trans/hyd. oil into the brake, then you got a whole 'nother problem. Follow the brake rods to the cover on the trans that is held on by six bolts (I think). Remove that and the brake shoes are behind there.
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
UNUSED SDLANCH IRET13 ELECTRIC TRICYCLE (A64280)
UNUSED SDLANCH...
2026 XStar 750 Gal Fuel Trailer (A64119)
2026 XStar 750 Gal...
2012 Ford Expedition SUV (A61574)
2012 Ford...
2024 SCAG SCZ61V Cheetah 60in Zero Turn Mower (A61572)
2024 SCAG SCZ61V...
