Replacing Brakes on B8200
/ Replacing Brakes on B8200 #1
AndyF
Bronze Member
Central NY
Kubota B8200 & B7200
I have an older B8200, probably early '80's which needs new brakes. I've reached the end of the adjustment range and it sounds like metal to metal when I use the brakes. How straightforward is brake repair on this tractor? I've done brakes on cars, but never on a tractor.
/ Replacing Brakes on B8200 #2
Don't you have wet brakes? They are more like a clutch on a
motorcycle than brakes you have had on any car.
If you decide to pull apart your rear axle to replace them, let
us know how it goes. I have never had to replace wet brakes
myself before. They are "lifetime" items for the most part.
/ Replacing Brakes on B8200 #3
The B8200 has dry brakes. Unless the shaft seal has started leaking trans/hyd. oil into the brake, then you got a whole 'nother problem. Follow the brake rods to the cover on the trans that is held on by six bolts (I think). Remove that and the brake shoes are behind there.
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
2014 Nissan Murano Cross Cabriolet AWD SUV (A61574)
2014 Nissan Murano...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
2019 FREIGHTLINER M2 4X2 S/A 26FT BOX TRUCK (A59914)
2019 FREIGHTLINER...
2018 CATERPILLAR 232D SKID STEER (A64279)
2018 CATERPILLAR...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
