Replacing Amp meter with volt meter on Massey Ferguson 135 Wiring.
   / Replacing Amp meter with volt meter on Massey Ferguson 135 Wiring. #1
tomcat48nov
Madisonville TN
Case IH 255 compact
My tractor does not have a ignition key. It only has a start switch. My problem is how to wire voltmeter in so it will not be on all the time?
   / Replacing Amp meter with volt meter on Massey Ferguson 135 Wiring. #2
Make an ignition switch by adding a switch in series with start switch.
   / Replacing Amp meter with volt meter on Massey Ferguson 135 Wiring. #3
It has an oil pressure switch that supplies power to the gauges and "ignition" type circuits when the engine is running. You can tie the voltmeter to that and it will function when the engine is running.
Thanks, that sounds good. Will check that out.
Was wondering, can I also use this same connection for exciting my alternator circuit to start charging my battery?
Thank you, was wondering can I use this same connection to excite my alternator to start charging my battery when starting?
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
2007 Peterbilt 379 T/A Day Cab Truck Tractor (A60460)
2007 Peterbilt 379...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
