Replacing Amp meter with volt meter on Massey Ferguson 135 Wiring.
   / Replacing Amp meter with volt meter on Massey Ferguson 135 Wiring. #1
tomcat48nov
Madisonville TN
Case IH 255 compact
My tractor does not have a ignition key. It only has a start switch. My problem is how to wire voltmeter in so it will not be on all the time?
   / Replacing Amp meter with volt meter on Massey Ferguson 135 Wiring. #2
Make an ignition switch by adding a switch in series with start switch.
   / Replacing Amp meter with volt meter on Massey Ferguson 135 Wiring. #3
It has an oil pressure switch that supplies power to the gauges and "ignition" type circuits when the engine is running. You can tie the voltmeter to that and it will function when the engine is running.
Thanks, that sounds good. Will check that out.
Was wondering, can I also use this same connection for exciting my alternator circuit to start charging my battery?
Thank you, was wondering can I use this same connection to excite my alternator to start charging my battery when starting?
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2013 VOLVO EC250DL EXCAVATOR (A60429)
2013 VOLVO EC250DL...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
