Replacing Amp meter with volt meter on Massey Ferguson 135 Wiring.
   / Replacing Amp meter with volt meter on Massey Ferguson 135 Wiring. #1
tomcat48nov
Madisonville TN
Case IH 255 compact
My tractor does not have a ignition key. It only has a start switch. My problem is how to wire voltmeter in so it will not be on all the time?
   / Replacing Amp meter with volt meter on Massey Ferguson 135 Wiring. #2
Make an ignition switch by adding a switch in series with start switch.
   / Replacing Amp meter with volt meter on Massey Ferguson 135 Wiring. #3
It has an oil pressure switch that supplies power to the gauges and "ignition" type circuits when the engine is running. You can tie the voltmeter to that and it will function when the engine is running.
Thanks, that sounds good. Will check that out.
Was wondering, can I also use this same connection for exciting my alternator circuit to start charging my battery?
Thank you, was wondering can I use this same connection to excite my alternator to start charging my battery when starting?
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
2014 BOBCAT E32 EXCAVATOR (A60429)
2014 BOBCAT E32...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56438)
2008 Ford F-250...
New Holland T2420 (A53317)
New Holland T2420...
Deere 310L (A53317)
Deere 310L (A53317)
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
