Replacing a cuttershaft bearing
  • Thread starter Deleted member 41266
  • Start date
/ Replacing a cuttershaft bearing #1
D
Guest
I have to replace a blown cuttershaft bearing on a Mott 72 flail mower and I don't have a manual. It looks like I can support the mower and prop up the shaft, then remove the bearing & housing and replace it.
Has anyone here done this or have some insight on how best to go about doing this?
TIA
Peter
/ Replacing a cuttershaft bearing #2
Mott was bought out byAlamo in 1983. You might try contacting either Alamo Industrial or Rhino and seeing if either could help you with a manual.
2015 Ford F-250 4x4 Crew Cab Pickup Truck (A66736)
2015 Ford F-250...
2009 Generac SD060 75kVA Standby Diesel Generator (A66734)
2009 Generac SD060...
2020 Komatsu PC210LC-11 Hydraulic Excavator (A66734)
2020 Komatsu...
PALLET OF HOSES (A68842)
PALLET OF HOSES...
ALLMAND  MAXI LITE 2 V (A67714)
ALLMAND MAXI LITE...
CULVERTS (A68842)
CULVERTS (A68842)
