Replacement Trailer Type & Sizing
/ Replacement Trailer Type & Sizing #61
Road surface is a mixed bag...
Trailer will have a load next week.
Dealer suggested the Super Duty might benefit from a suspension upgrade?
/ Replacement Trailer Type & Sizing #62
If the trailer came with a full 80 psi in all tires and there's no load, it will react to any road imperfections.
Ideally the trailer's pressure should be adjusted to match the load on the tires, just like with the tow vehicle.
I doubt that the tow vehicle's suspension is at fault here, but am not surprised that a dealer would suggest it.
/ Replacement Trailer Type & Sizing #63
You are right and I adjust tire pressure on 2 of my other trailers...
I will check...
Thank You...
Sometimes I forget what I forgot...
/ Replacement Trailer Type & Sizing #64
Also, it may take a few miles for a new trailer suspension to start moving somewhat freely.
A run with a decent load should help with that.
/ Replacement Trailer Type & Sizing #65
After taking a 200 mile road trip to get new tires on the tractor I did notice the ride is smoother with the trailer behind me. I think the problem is the truck suspension needs the weight on the rear axle to have some travel. Otherwise the stiff suspension has no give.
/ Replacement Trailer Type & Sizing #66
Checked Tire Pressure tonight and the max 80 psi tires are between 91 and 95 psi... So 20% over max and this was at temp in the mid 50's
Trailer has two 7,000 lb axles...
/ Replacement Trailer Type & Sizing #68
That would make it hop on every road bump.
I was not along for the ride home… only heard about it.
Back when I worked at a dealership put of my teenage duties was making sure the tank was topped off, all tires properly inflated and check all fluids.
Seems like no one checked the trailer prior to delivery?
/ Replacement Trailer Type & Sizing #69
What I have found over the years with different trucks and trailers, is, the balls location. If it is too far forward, the harmonic frequency seems to rear its ugly head. I can't really explain it. It seems to only happen under light throttle, pulling. Hard pulling, coasting and easy cruise, all is well. My '21 with the factory hitch is smooth. My other three trucks that I mounted the hitch on:D, buck. I have them all forward quite a bit. The Ram is almost centered.
/ Replacement Trailer Type & Sizing #70
It's the pop up location when factory propped for the GN
If memory serves it's slightly ahead of the rear axle...
/ Replacement Trailer Type & Sizing #71
Again not to rehash, your 2nd point isn’t true, makes no difference. Hauling stuff with a GCWR over 26k regardless of commerce. Many states do have the farmer exclusion.
But I think dealers owe it to new buyers to let them know that since the GVWR of these newer trucks are so high that pretty much any 10k+ trailer requires a CDL. Glad this dealer is discussing it so it is not a surprise.
This isnt a new thing. 14k is s pretty common trailer size. And for over two decades or more, any dually rolling off the line would put the combo over 26k also.
This isnt opinion. And lots of people have mis-informed opinions. And lots of LEO's dont even know the laws.
But no, if you are not hauling commercial, you dont need a CDL. Some states may have different "classes" of non-commercial licenses though. Often why you see many setups with "not-for-hire" on the side. NO, thats not because they get tired of people bugging them to haul something for them;)
/ Replacement Trailer Type & Sizing #72
Did OP ever find a trailer?
Nope still looking but it’s ear in the process.
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
John Deere 2155 Tractor W/ Loader (A62613)
John Deere 2155...
PREVIEW DATES AND TIMES (A65579)
PREVIEW DATES AND...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2016 Ram ProMaster 2500 Cargo Van (A61573)
2016 Ram ProMaster...
1999 JOHN DEERE 344H WHEEL LOADER (A63276)
1999 JOHN DEERE...
