Replacement tires (Versa Turf) verification
/ Replacement tires (Versa Turf) verification #1
Ira
Can someone please verify that these Versa Turf tires are the correct sizes to replace the factory industrial/R4 tires on a new CX2510HCB, e.g., same wheel size, no modifications needed, no extra parts needed?
Rear - Versa Turf 12R16.5 (SKU 6L13541)
Front - Versa Turf 23x8.50R12 (SKU 6L13551)
Anyone who has put these on a CX2510, care to comment on them?
/ Replacement tires (Versa Turf) verification #2
Compare rolling circumferences. Max allowed difference I believe is 5%. Fronts should turn a bit faster due to steering.
Call your dealer.
Why not Kioti factory R14?
Tractor on dealer's lot has R4's. Getting factory R14's would cost me more than getting the Versa Turfs. I'm sure R14's would be better than R4's, but the Versa Turf reviews make them out to be the best tire for my purposes.
/ Replacement tires (Versa Turf) verification #4
Did you ask if you could get an even swap? I know I went from R14 to R4, but I wanted tire strength. They advertise choice of tires...
/ Replacement tires (Versa Turf) verification #5
There is no cost difference between the two tire options on Kioti's website; I'd push it. Worst comes to worse you go with the Carlisle's you were planning on.
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A61306)
2023 Takeuchi TL6R...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
VOLVO A40D OFF ROAD DUMP TRUCK (A60429)
VOLVO A40D OFF...
2022 CATERPILLAR 303.5CR EXCAVATOR (A60429)
2022 CATERPILLAR...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
