Replacement seat
/ Replacement seat #1
Fastball
North Okanagan, British Columbia
Kubota L2900
Got a new seat for my L2900 (late 90s) for Xmas.The Kubota guy told my wife it was a generic replacement type, and SHOULD fit. The original seat bottom has 4 threaded holes lining up with the holes on the hinges on the seat base. The new seat base has lots of threaded holes all over the places, but only TWO holes match my hinges. So basically, instead of 4 bolts holding the seat on the hinges - I would only have TWO bolts securing it in place. If the attached pics work - the first is the original - the second is the new seat with the matching holes indicated in green. Would two bolts be sufficient instead of the four original ones?
Has anybody done this - or care to offer an opinion?
/ Replacement seat #2
Those original four look close together. Not sure the two would have that much less holding power. Don't forget, YOU are holding it down too. :laughing:
That's a thoughtful wife. Sure beats a gift card. ;)
If it does pose a problem, a simple plate to match the hinge and new seat should work. You could then put as many bolts as you want in the seat. :cool:
/ Replacement seat #3
Make two angle pieces longer than the factory ones and bolt away!
John Deere 12ft pull-type cultimulcher, Orion, IL (A65640)
John Deere 12ft...
Teakwood Rocking Horse (A65583)
Teakwood Rocking...
2020 WESTERN STAR  4900 TRI AXLE (A65643)
2020 WESTERN STAR...
Caterpillar 215C LC Crawler Excavator (A66285)
Caterpillar 215C...
2004 STRICK 53X102 T/A DRY VAN TRAILER (A59914)
2004 STRICK 53X102...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
