Replacement rear blade edge source
/ Replacement rear blade edge source #1
Michael In Tennessee
Niota, TN
Kubota MX4800HST
I have an ancient Servis 6 way rear blade that was badly abused in a former life. The blade was badly bent and badly welded back together. I can fix the blade with a bit of cutting and welding. But, the cutting edge is broke in half. I need to find a serviceable replacement that is budget conscious.
Agrisupply has a blade that might work for $150, but shipping is $170!!!!!.
The cutting edge is 72 wide, 5" high and not reversible. The bolts are 1 ft on center except the ends have double bolts 3" on center. The bolt holes are 1 1/2" from the top edge. The agrisupply blade is 6" and reversible, so I'd have to double check if I can drill new holes.
I only have $150 in the whole thing. I bought it to cut one ditch and that was finished as couple of years ago, so the blade owes me nothing. If I use it lightly, I can use it in its current condition. It would be nice though to get it in better shape.
Any ideas on a replacement cutting edge?
/ Replacement rear blade edge source #3
My BIL was district supervisor for the county highway dept. He got me a brand new road grader blade. Ten feet wide - six inches high - one and a half inches thick at the back. It took me two days to cut it down to 96". All I have is a hack saw. And another day to drill the holes to bolt it on my rear blade.
I used my hydraulic floor jack to raise it up - to align the bolt holes. I laid it on my bathroom scales - 253 pounds.
Anyhow - you might want to check with your county highway dept. See what their discarded road grader blades look like and what they do with them.
/ Replacement rear blade edge source #4
you may give EA a call, they must make replacements for their stuff, and the bolt pattern sounds like its the same as the land shark series stuff.
i think it's same pattern as my bison as well, but mine is reversible.
i bet if you know any local machine shops, that you can just order a hardox flat bar and have them water jet the square holes for carriage bolts. Would be a super easy job for them.
/ Replacement rear blade edge source #5
Check with Rhino. They were at one time called Servis
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Hyster S50XL Forklift (A65579)
Hyster S50XL...
John Deere Metal Sign (A65583)
John Deere Metal...
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
Duratech HD 8 Tub Grinder (A62613)
Duratech HD 8 Tub...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
