Oil & Fuel replacement of fuel pump
   / replacement of fuel pump #1
lowufo
warren maine
JD 300 industrial 1965-73 era
Hello Everyone
just replaced me starter that was toast with an after market unit. Problem is that the fuel pump won't go back into the block all the way ( about 1/4 " ) short of the block before the bottom of the pump hits the starter.Questions: 1. can I build the pump out from the block with gaskets and have the pump still work ? 2. can I grind a little of the bottom of the pump casing off to make it fit ? 3. Can I just replace it with an electric fuel pump ? If so any special pump needed ?
Thanks for all the advice
lowufo
   / replacement of fuel pump #2
If you move pump back away from block you'll also be moving it away from the camshaft lobe that operates the pump. Yes an electric fuel pump can be substituted for the manual pump. IIRC JD offers a plate to cover hole in the block.
what does IIRC JD stand for
Thanks !!!
City of Tampa (1202)**Title MUST be transferred into buyer's name INCLUDING DEALERS. All titles (A51692)
City of Tampa...
PRESSURE WASHER GAS (A52472)
PRESSURE WASHER...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
