Replacement lights-2007 CK 25
/ Replacement lights-2007 CK 25 #1
ASTROENG2011
Bullard, Texas
2007 kioti ck25, Cub Cadet 3204, Kubota G5200HST
I have a 2007 CK 25 tractor. I love it and have used it both hard and very lightly and it has never let me down. Typical maintenance etc. I have damaged( nearer to destroyed ) the ROPS mounted amber flasher light on the driver side. I have looked online for replacement but I do not see any part number for such. I would like to replace it with as close to an exact match as possible. It has a threaded base with wiring coming from it and then rubber or similar mounting material wrapping around its outside perimeter. I have looked at various replacement lights from several sources but do not find the correct one. Any one have any ideas? Lights?
/ Replacement lights-2007 CK 25 #2
Is it in here? Click on this link Error
Looking on line, I see the ROPS assembly but no lights or the small metal brackets to hang them on are shown. Image-CK30M-980A.jpgI am wondering of it was a dealer add on. Looks like factory and the wiring appears to be factory including the welded on tabs that wrap around the wiring.
/ Replacement lights-2007 CK 25 #4
Post a pic of your old ones.
/ Replacement lights-2007 CK 25 #5
Hi
I have a Kioti CK2810 HST with lights for road use. The lights on the ROP are incredibly vulnerable and it surprises me that Kioti don't give them any protection. I have nearly 600 olive trees and although I have a Muratori flail which moves out to the side to get under the trees I soon found that however careful I was sooner or later a lurch due to ground undulation (often the fault of the sanglier we have here - wild boar - which can really make a mess of the ground) or my misjudgement meant a light was swiped. So I had the right hand light kept together by duct tape for a while until I got one our local blacksmiths to make a cage to go around the lights. This has been very successful and having got my dealer to get me a replacement light I've had no more problems despite testing the cages severely (not intentionally).
Strange that Kioti don't even offer this as an option. After all they could make money from it.
  • KiotyLightguard.pdf
Found a replacement on line at Tractor Supply. Local store does not carry this light but I can order it online. "Blazer Double Face Lamp-Amber" SKU# 0165664--listed at $6.49.
OK, I finally remembered to take pics of old lights for reference. 0929141714.jpg0929141715.jpg0929141715a.jpg
(2) HAY TEDDER WHEEL RAKES (A64280)
(2) HAY TEDDER...
11in. Tooth Excavator Bucket (A64194)
11in. Tooth...
2015 Ford F-350 Auto Crane Service Truck (A61573)
2015 Ford F-350...
2019 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A59912)
2019 FREIGHTLINER...
2015 Chevrolet Silverado Pickup Truck (A62613)
2015 Chevrolet...
Caterpillar Engine Parts and Service Manuals (A63117)
Caterpillar Engine...
