Replacement Ignition Keys
/ Replacement Ignition Keys #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
Where is a good place to stock up on some ignition keys?
A quick internet search pointed me to $22 to $27 per key.
The key is simple so I was expecting something much cheaper.
TIA
Yooper Dave
/ Replacement Ignition Keys #2
What are the keys for? If it is the newer transponder keys, then that price is a steal.
/ Replacement Ignition Keys #3
X2
You posted in the LS forum but don't list an LS as one of your tractors.
/ Replacement Ignition Keys #5
partsforlstractors.com has keys for $15.34
The part number is 40230393.
I don't know the price but the same key can be purchased at New Holland, Case, Farmall dealers. Same part number but with an MT in front of it.
Your XJ should have come with 2 keys.
The 40230393 number has been superceded and can also be ordered as 40266850 or MT40266850 for under $15.
Do you know if the Kioti Key is an equivalent match? The Kioti provides a picture and looks close.
Thanks
Yooper Dave
/ Replacement Ignition Keys #7
I do not know if Kioti is the same. If the Kioti key part number is the same then the key is the same but I don't know the Kioti part #.
/ Replacement Ignition Keys #8
All new tractors come with 2 keys. I purchased 2 extra from the dealer for $30.
I ordered 4 keys for ~ $30 delivered to my door. Thanks for the help.
Regards,
Yooper Dave
/ Replacement Ignition Keys #10
The XJ has the key in an easily damaged location. Many of us have redone it. My key stays in the tractor. lois knob.jpg
/ Replacement Ignition Keys #11
I know this is a very old post.
Buy your keys from heavyequipmentkeys.com. I just purchased three keys for $3.00 each plus $4.50 shipping for a total of $13.50. Doesn't hurt to keep a couple of spares around for that price.
Odd but they ship from Hawaii. Never dealt with a Hawaii supplier before.
/ Replacement Ignition Keys #12
Po
Pop A Lock made me 2 for $3.00
/ Replacement Ignition Keys #13
Thanks for the info. I purchased two cut keys for my truck off the internet. The manual had directions how to program but I never could get the keys programed. Others on the internet had the same complaint, that the directions didn't work. I ended up taking to the dealer and they charged some rediculious fee to program. (can't remember the exact cost now). Pop A lock seems like a good resource. I never heard of them before. I will keep them in mind.
/ Replacement Ignition Keys #14
I wonder if the LS keys are like the key for my JD.
I lost one and took all the serial numbers and model numbers etc to a JD dealer and asked if they could order me a new key.
Parts guy says he doesn't need all the VIN info because they use the same key.
Opens up a drawer and gives me another key. Cost around $5.
/ Replacement Ignition Keys #15
dealership bent my MT240 key twice somehow. Each model uses the same key, so they have them in stock, just grab and go.
/ Replacement Ignition Keys #16
Why not get blanks and cut your own??
jewers files work just fine
willy
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
(1) 420/70-24 TIRE W/ 6 LUG RIM (A64280)
(1) 420/70-24 TIRE...
Bobcat A770 (A60462)
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
2020 CATERPILLAR 299D3 SKID STEER (A64279)
2020 CATERPILLAR...
2019 CATERPILLAR 299D2 SKID STEER (A64279)
2019 CATERPILLAR...
