replacement geothermal heat pump
   / replacement geothermal heat pump #1
irvingj
Elite Member
Etna, NH
2007 MF GC2310 TLB
My old (23 years!) hand-made heat pump finally quit a few weeks ago.... Back when we were still getting snow!
Well, the replacement's here, and is now being installed. Should be completed & ready for testing later today. I think I'm gonna say "ouch!" when the bill comes in, but Water Furnace is supposed to be a good brand.
Third pic is the original; new one's next larger size in BTU, but also larger period! Certainly looks like it would be a LOT easier to work on, at least- lots more space inside for sure!
  • Heat pump 11:08.JPG
    Heat pump 11:08.JPG
   / replacement geothermal heat pump #2
We have a Water Furnace that's ten years old. I consider the Water Furnace brand as the Cadillac. Yours' sure does has a super jumbo size air filter on the side of it. I can see the twinkle in the salesman's eye when you ask for the price on this puppy!
   / replacement geothermal heat pump #3
Is that the Synergy 3D model? Looks just like ours except ours is red.
We put one in our new house last summer.
EDIT: Nevermind, that must be the Envision which I see looks the same but is blue.
Yep, Envision series.
It's quite a bit larger than I expected; my old one was around 2.5 tons, I think... got a solid 24,000 BTU figure based on water loop TD and GPM, then add internal heat, etc. I always felt it was a tad toward the marginal side, however; it'd do the job in the winter, but it ran a lot and I alsways felt better helping it out with the woodstove during the really cold spells, so I asked for a larger unit.
What was sent to me is 42,000 BTU :eek:-- I just hope it's not too big. Right now I'm in the process of ripping out the old 30-amp circuit and replacing with the --now-- necessary 40-amp circuit.:mad:
Oh, well.... it's only been about 25 years since I was in HVAC- it does come back, but I'd hate to have to pay me by the hour!!:laughing:
Here it is in its "dress blues" as it were...
Water loop repaired, flushed, charged & tested with temp 115V hook-up, 8.2GPM; DHW loop completed & tied in, ductwork also tied in. This unit has an internal circulator pump for the DHW desuperheater, so my old Grundfos on that side had to be pulled out....
Just waiting for the electric now.
Man, I forgot how much fun it is to work with #8 4-conductor wire!
   / replacement geothermal heat pump #6
We replaced a 15 year old Hydro-Heat unit last year with the same Water Furnace unit (Envision) that you have. I also purchase the hot water heater option and after seeing your pictures -- I need to get it hooked up.
The Geo unit is great both winter and summer. I assume you also have the 2-stage compressor.
We live approx 40 miles from the Water Furnace plant in Fort Wayne and I pick-up the unit for our contractor at the plant. It's a busy place.
Water Furnace is proud of that air filter. It is 30X32X2 model PWG-2. It is actually two 30X16X2 filters taper together.
Do you run with the cold air return open as shown? We use duct work to bring return air back to the filter from 3 different room locations.
One final note -- I see you have a Jetta TDI. We have had two. Current 2006 just turned 70K and we love it. Overall average 43mpg. Interstate driving 50+
   / replacement geothermal heat pump #7
The desuperheater sometimes seems to be blown off as an over rated accessory. It's not. The comfort of the even water heating, quick recovery, and low wear and tear on the water heater is pretty remarkable with the desuperheater.
Mr. Wilson-- yes, it does have the desuperheater. My old unit, which was a custom-made one-off thing, also had a full condensing coil in addition to the desuperheater, so it had the capability of doing nothing but make hot water. I decided not to go for that additional option on the Water Furnace, but to stick with the desuperheater.
I'll admit it was very nice to know that, during A/C, house heat was being put directly into the DHW system, but it did add another level of complexity. Further, due to the nature of the system, refrigerant condensing temp in the winter was actually less than you'd normally keep your hot water at, so the unit would constantly go back & forth between hot water and house heat and never shut off: After getting water temp up to 125 or so, as soon as house heat was called for heat from the hot water tank would migrate through the desuperheater loop to the cooler refrigerant; as soon as house heat was satisfied, water temp had dropped..... and so on.
My solution was to set DHW t-stat as low as it would go (85+/-). The desuperheater, during the heating season, would keep the tank right around 90. When I wanted showers, laundry, etc., I just turned on the upper element in the water heater. Only took about 15 minutes to bring it up to 125. I'll do the same with the new one. As Whistlepig pointed out, the desuperheater really does work. As the unit I purchased already has a built-in circulator pump for the desuperheater I had to pull my old one, so you might be all set in that regard. Otherwise, it's just a matter of hooking up a loop to your existing water heater. I used the bottom drain and the hole from the lower element for my loop. You may notice that I also oversized both the expansion tank and the water heater- both are 80-gallon.
Yes, I run the return open like that; I had originally planned to duct it, but then realized that it was great for air circulation, not just for the house but also for the basement. Really cuts down on moisture build-up --and sometimes condensation-- on the cellar walls & in the corners, and allowed me to pull warm air from the basement from the woodstove to augment heat during really cold periods. I also have a whole-house heat recovery ventilator that brings fresh, warmed outside air into the basement, which is also picked up by the heat pump air intake. (Man, that's a lot of "also"s!)
This is my first TDI, the first NEW car I've ever bought for myself (wife gets the new ones...:D), and my second diesel- had an 82 Peugeot 504D wagon for a few years. I became convinced of the desirability of diesel quite a few years ago; even once investigated replacing the 307 V8 in my 72 Blazer with a diesel-- and was told it wasn't possible; the truck would shake itself apart... this was obviously before diesel in light trucks & cars caught on in the US, back in 1975 or so....
Mine's an 05 with the PD engine. Only has 65K on it now, but gets similar mileage- on a road trip, if the A/C's not on, it'll do 50 (with A/C 45-48); around town about 42-45. Good for around 850 miles on a full tank.:thumbsup: Love that!
   / replacement geothermal heat pump #9
wow, that is one big unit: i bet that makes it kinda hard to install in an existing home that folks like me didn't think about allowing the kind of space required?? how loud is that going to be when the compressor is running?
heehaw
   / replacement geothermal heat pump #10
Heehaw,
I've got basically the same unit as irvingj, when it's running it really pretty quiet. The only time it's loud (and I say that lightly) is right when the compressor actually kicks in and that's only for about a second.
These units are pretty well closed up and sound insulated pretty good.
bad boy zero turn 72 (A56859)
bad boy zero turn...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
Caterpillar Loader Quick Coupler (A56436)
Caterpillar Loader...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
