Replacement flasher lights
/ Replacement flasher lights #1
jcummins
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
I had an M7040 tractor in Texas. Tore those flasher lights off, sold tractor that way. Now with a different M7040, did the same thing. You'd think I'd learn. But mowing around woods without a batwing mower, seems you can't help but get into the limbs.
What's the solution? Different lights that aren't plastic? Build a bracket around the lights? Where's the best place to get replacement lights. Prefer something different than the plastic ones.
/ Replacement flasher lights #2
Use the clicklock surface mount posts and build a bracket to mount them on the fact of the ROPS with a metal guard around them.
/ Replacement flasher lights #3
i have more issues with lights on trailers. and weeds grabbing a hold of a wire and ripping out the wire.
it has gotten to a point on a couple things were i would say one of these days i will just make a "quick connect" plug for the wires. so when something snags. the plugs will come apart. and i will not have to re-run new wires and or attempt to splice wires back together. needless to say i end up running metal pipe / fittings to locations. and ran wire through the metal pipe.
now i just curse things. when i some how manage to pull wire apart. and the wire will not pull out of the metal pipes. due to the metal pipe got bent up / crimpped together some place. and holding the wires in it. and not enough room in pipes to fish another wire or 2 through the pipe.
darn if you do, darn if you do not.
my biggest issue with replacement lights = getting correct type of bulbs. wrong amp / wattage = not as bright, or to bright and burn up quickly. your flasher relays may only be rated for a certain amount. before you fry them. so again double check amps/watts used when getting replacement lights.
Mobark Beever M12RX Wood Chipper (A65579)
Mobark Beever...
1991 FRUEHAUF 45'X96" FLATBED TRAILER (A65643)
1991 FRUEHAUF...
2016 Jeep Compass SUV (A64557)
2016 Jeep Compass...
1999 Sterling Dump Truck (A66285)
1999 Sterling Dump...
Parker Gravity Wagon (A66285)
Parker Gravity...
(12) John Deere 1.5bu. Seed Boxes (A65640)
(12) John Deere...
