Replacement 7TL Curl Cylinder
   / Replacement 7TL Curl Cylinder #1
madhouse
Minnesota
Bobcat CT230
I managed to bend a curl cylinder on my 7TL. Bobcat wants $900 to replace or $330 to replace rod and seals.
Has anyone found a cheaper option?
   / Replacement 7TL Curl Cylinder #2
Reach out to Brian ( MtnViewRanch) He is a member her and knows hydraulics.
   / Replacement 7TL Curl Cylinder #3
Got my curiosity up and I have googled for a couple of hours. Seems the specs on these cylinders are a little odd. I have not found anything even close. Doesn't mean it is not out there. Have you spoken to any hydraulic shops in your area?
I have only called Bobcat up to this point.
My next step was to throw it out on here and let people much smarter than me point me in the right direction. :D
   / Replacement 7TL Curl Cylinder #5
Just curious, how did you bend it?
   / Replacement 7TL Curl Cylinder #6
If you just bent the rod stick it in a press and straighten it .
I broke the pivot point off the loader arm with a over-sized bucket full of snow. It twisted the other pivot and bent the rod.
   / Replacement 7TL Curl Cylinder #8
That's a very slight bend easily straightened. As for the pivot points a machine shop may be able to get you back in action.
   / Replacement 7TL Curl Cylinder #9
Thanks for the info
I think I am going to have a close look at my loader arms......
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A51039)
2004 Capacity Yard...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2015 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2015 MACK GU713...
