Replacement 7TL Curl Cylinder
   / Replacement 7TL Curl Cylinder #1
madhouse
Minnesota
Bobcat CT230
I managed to bend a curl cylinder on my 7TL. Bobcat wants $900 to replace or $330 to replace rod and seals.
Has anyone found a cheaper option?
   / Replacement 7TL Curl Cylinder #2
Reach out to Brian ( MtnViewRanch) He is a member her and knows hydraulics.
   / Replacement 7TL Curl Cylinder #3
Got my curiosity up and I have googled for a couple of hours. Seems the specs on these cylinders are a little odd. I have not found anything even close. Doesn't mean it is not out there. Have you spoken to any hydraulic shops in your area?
I have only called Bobcat up to this point.
My next step was to throw it out on here and let people much smarter than me point me in the right direction. :D
   / Replacement 7TL Curl Cylinder #5
Just curious, how did you bend it?
   / Replacement 7TL Curl Cylinder #6
If you just bent the rod stick it in a press and straighten it .
I broke the pivot point off the loader arm with a over-sized bucket full of snow. It twisted the other pivot and bent the rod.
   / Replacement 7TL Curl Cylinder #8
That's a very slight bend easily straightened. As for the pivot points a machine shop may be able to get you back in action.
   / Replacement 7TL Curl Cylinder #9
Thanks for the info
I think I am going to have a close look at my loader arms......
Toyota 6FGU25 Forklift  5,000 lb Capacity (A51039)
Toyota 6FGU25...
OIL WORKS INC. AIR TONGS (A50854)
OIL WORKS INC. AIR...
2018 Ford Escape SUV (A50324)
2018 Ford Escape...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
