Replaced engine on my PT422
   / Replaced engine on my PT422 #43
Started taking engine out of my 422 today , done with the easy stuff now to tackle the harder things I think. Found something that could have been bad, the positive cable from the battery to the starter had all the coating rubbed off several places and the copper wire was showing, glad I caught that before something bad happened. Trying to figure out how to get the engine mounting bolts loose , one looks like it is going to be real hard, (under starter) the others look not quite so hard.
I got that bolt partly from the oil drain access hole. It helped to have a second person. I think I reached from the front of the engine with my left hand to get to the top of the bolt.
   / Replaced engine on my PT422 #45
Got all the bolts except that one , cannot keep wrench on top of bolt to keep from spinning. I did like you said reach the nut on the bottom through the oil drain access hole . My son tried to hold wrench on bolt top but it kept slipping off . Bolt is loose but cannot get nut off completely. Did you have to slide engine forward to get rear pump free of motor?
Not sure. I don稚 think so. It did not take much engine movement to clear it. I think the nuts on the engine bolts are nylock.
   / Replaced engine on my PT422 #47
Its out and what a mess 19 years of crud built up even though it was cleaned out often. Going to clean it out as best I can and then decide what I am going to do for a replacementView attachment 565399View attachment 565400 P1010014 (1).JPGP1010015 (1).JPG
   / Replaced engine on my PT422 #49
I have another 22 hp Robin that I purchased used years ago for parts or a backup. I have not decided if I want to put it in or not. I used the 2 ignition coils off it on the engine I just took out so I would have to replace them and they are not cheap. I am not sure how many hours on the replacement engine and if sitting in my garage for probably 10 years could have any ill effects on it. I do not want to put it in and find out it is no good or subpar.
   / Replaced engine on my PT422 #50
(since it's not my money) Go Big or Go home!
I would at least drop in a 25hp... or bigger. Field mowing with my PT422 is a royal pain 'cause not enough power.
It was not available for my tractor. Check with Terry. I would have loved to have the extra horsepower.
   / Replaced engine on my PT422 #52
The Hondas and clones are a good match... The 670 is good or 690 for a bit of an upgrade.
There is some machining done on the back of the engine that allows the pumps to bolt on. My guess is it was done by Power Trac. Anybody else notice this?
   / Replaced engine on my PT422 #54
Bob did you cut your blower housing in half like you did on your old engine? If so where and how did you cut it and fasten it on
I did cut it. I cut horizontally across at the engine shaft center line. I used the existing bolts to hold it in place. I can now get in there and clean the engine. I used a spiral bit on my Dremel tool. Not hard to cut.
   / Replaced engine on my PT422 #56
I never took notice of my motor location in the tub on my old engine, but my new engine sits off center a little bit, the side where the starter is located is almost touching the tub wall and the rear pump is slightly off center also. Do I have the motor mounted wrong or is that common with the older 422's? I measured the platform that the motor sits on and it is also not exactly centered. I did not remove the platform or loosen its bolts so I don't think it moved any.
I will try to check later today.
I noticed the same offset on my engine. The starter side is about one inch between the engine and side and the other is about 2 inches.
   / Replaced engine on my PT422 #59
Great job Bob on the engine replacement. :thumbsup: I am getting ready to cut away my housing wondering if you have a picture of yours with the cut away. I am replacing the ignition module's on my Kohler 25.
Deere 331G (A53317)
Deere 331G (A53317)
2006 Chevrolet Express 3500 Cargo Van (A59230)
2006 Chevrolet...
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
