Replaced engine on my PT422
   / Replaced engine on my PT422 #11
If you look at the VVP pump picture, you'll see a thick black vertical plate between the VVP and engine. That vertical plate goes down and meets the end of the horizontal engine mounting plate.
I was wondering how the pumps bolted to the engine on the stub shaft mounted on the fan end, since the fan would get in the way of any bolt holes.
I guess I see why PT went to stacking the pumps; a lot less work then using both ends of the engine.
Would be nice, however, to put the exhaust manifold at the back end of the tub instead of in the middle over the top of the pumps (and right next to the gas tank).
   / Replaced engine on my PT422 #12
Yeah, they have a little more cost with adding the stub shaft, but I'd guess they have a little more cost getting a VVP with an output shaft to drive the stacked PTO and Steering/lift pumps.
On you folks that have all three pumps in front of the engine, is there a bracket that hold up the pumps, or are they all hanging off the engine mount?
I removed the gas tank with support bracket. I did not disconnect any hoses except the fuel line. Just unbolt the pumps from both ends of the motor and unbolted the engine from the support base (4 bolts). I also pulled the exhaust system off and removed the battery. The motor to support base bolts were a little difficult to get to. A neighbor, bless his heart, helped a whole lot. I borrowed an engine hoist from another neighbor, bless him to.
I changed the hydraulic filter while the engine was out.
It sounds easier than it was. But it was not real difficult. There is a connector you unplug for most of the electrical wires. Also you must pull the battery cable and a couple of more wires off the starter and remove the engine ground. Take a picture of the throttle and choke cables before you remove them.
I hope I did not forget anything here. Oh, don稚 forget to align the Lovejoy connector before tightening the motor support bracket bolts. Instructions can be found on Lovejoy web site.
Here's some pics of my 2001 425 with the Kohler. PTO/Steering pumps behind the engine, variable volume tram pump in front of engine.
The PTO/Steering pumps are attached to the factory output shaft on the Kohler.
The VVP is attached to a stub shaft that comes through a hole cut into the fan guard. That stub shaft is a factory part from Kohler for those kinds of applications.
I'm gonna guess the 422 was set up the same way.
Looks very similar.
   / Replaced engine on my PT422 #15
The way you write it up, sounds like an hour job! :)
Nice overview. :thumbsup:
I think more like 12 hours.
I had to wait over the weekend for the new Lovejoy connector.
Oh, I also spent over an hour cleaning the tub of oil, grass, sticks and what ever else. I started with a vacuum cleaner then compressed air and then a garden hose. I also painted the battery shelf.
   / Replaced engine on my PT422 #17
All of them are just bolted to the side of the engine. No support bracket.
   / Replaced engine on my PT422 #18
on mine the pumps are bolted together and then the rear flange is bolted to the engine mount....there are no brackets or seats it just cantilevers off the flange bolts
pump.jpg....Jack
   / Replaced engine on my PT422 #19
View attachment 563893....Jack
Interesting. I'd have thought there'd have been a support bracket. Thanks. Just curious as to all the different setups/generations that we've seen over the years. Hard to believe mine is 17 years old already.
   / Replaced engine on my PT422 #20
I've noticed my battery shelf is also getting a bit rusty. Next time I remove the muffler to change the battery, I'll be scraping and painting as well.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
3ft Metal 5-Point Star (A59231)
3ft Metal 5-Point...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
John Deere TX Gator (A60462)
John Deere TX...
2017 CATERPILLAR 120M2 MOTORGRADER (A59823)
2017 CATERPILLAR...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
