Replace hydraulic fluid based on time, not hours?
/ Replace hydraulic fluid based on time, not hours? #1
Elkins45
KY
Kubota L3800
My Kubota L3800 will be 10 years old this fall and will probably hit around 220 hours. The manual says the hydro fluid is supposed to be replaced at 400 hours, but that’s a long way down the road given my rate of usage. I’m thinking it might be a reasonable thing to go ahead and replace it at 10 years just as a preventative measure. The first fluid change would probably last the rest of my life anyway.
/ Replace hydraulic fluid based on time, not hours? #2
/ Replace hydraulic fluid based on time, not hours? #3
t won't hurt anything to do so. No oil lasts forever and they do break down over time as well. Don't go cheap on the quality of the oil. Change the filter too. Does the dealer have a kit for this??
/ Replace hydraulic fluid based on time, not hours? #4
Get Kubota super utd2 and 2 filters, HST and Hydraulic....
/ Replace hydraulic fluid based on time, not hours? #7
I do neither. I'll pull a sample and send it to Blackstone Labs and have them tell me if it needs renewed. Your gear trans still has at least one filter because the transmission fluid is the hydraulic fluid as well.
/ Replace hydraulic fluid based on time, not hours? #8
Do you keep the tractor in a garage? or outside? It surely will not hurt anything (other than your wallet) to change it. If it was HST, I would worry more about the oil but since it's gear, I wouldn't worry much about it.
Have you checked your front axle oil level? Back in the day, they were usually very low on oil from the factory and unless you had a great dealer... it remained very low!
/ Replace hydraulic fluid based on time, not hours? #11
Doesn't hurt. 10 years is a bit of time for condensation to form. If it were mine I'd change it.
/ Replace hydraulic fluid based on time, not hours? #12
We have tractors made in the early 1980's. Never done a hydraulic fluid change. We have changed the filter a few times because it was dirty. We have 6 tractors. Commercial farm. They get used daily.
/ Replace hydraulic fluid based on time, not hours? #13
no use in changing it if it doesn't need it. I agree with 5030, send it to blackstone.
/ Replace hydraulic fluid based on time, not hours? #14
/ Replace hydraulic fluid based on time, not hours? #16
It’s 7.5 gallons. That’s not what I consider a small volume.
Everything is relative.
My 359 Pete's Cat engine holds 10 gallons of oil (yes, it's technically a tractor), and the M6040 hold around 15 gallons of hydraulic fluid. Some of the other machinery hold quite a bit more.
/ Replace hydraulic fluid based on time, not hours? #17
The same logic could also be applied to all the OEMs hourly service recommendations for fluids. Test it and change it based on the test results. Would recommend changing the filter(s) though.
Of course now one has to consider how often does one test it vs following the manufacturers recommendation for replacement.
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63688)
2023 Top Air ATV...
New/Unused CFG Industrial NT18K Mini Excavator (A65583)
New/Unused CFG...
2005 International 4300 55' Bucket Truck (A62613)
2005 International...
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
2018 Kenworth T680 (A64127)
2018 Kenworth T680...
Caterpillar 306 CR (A64126)
Caterpillar 306 CR...
