Oil & Fuel replace fuel filter on bx23
/ replace fuel filter on bx23 #1
clapton
does anyone know if i have to relieve the fuel pressure on my bx23 before changing the fuel filter,if so how do you do it ?
/ replace fuel filter on bx23 #2
There are two fuel filters on a BX23.
On the 1st filter, the one under the tractor just before the electric fuel pump. the pressure you'll encounter is gravity induced but depending upon how fast you can swap the 1st filter (the one before the fuel pump) you could lose a 1/2 pint to a gallon of fuel :D
That said, since the fuel line is rubber, some folks have used a pr of vice grips and/or hemostats (roach clip for you children of the 60's :D) to seal off the line about 4 nches or so before the filter, this should stop or slow the fuel flow enough to change it out without much lose in the gold-plated fuel.
The 2nd filter which is located in the engine compartment just before the fuel injector pump will leak some too but not as much as the 1st filter.
Good luck
/ replace fuel filter on bx23 #3
I suggest that you clamp the rubber fuel line near the first filter, as explained by Volfandt, and then proceed to replace both filters. You can also use some newspaper to catch the small amount of spillage.
Cowboy Statue (A64557)
PITTSBURG 2R CULTIVATOR FRAME (A64278)
PITTSBURG 2R...
2026 SDLANCH SDLC1220 High-End Carport (A64194)
2026 SDLANCH...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2019 BOBCAT E26 EXCAVATOR (A63276)
2019 BOBCAT E26...
Ford Pickup Truck Bed (A64556)
Ford Pickup Truck...
