repairing landscape rake
/ repairing landscape rake #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
While ago i built a landscaping rake using trailer spindle for the pivot. pretty soon the spindle snapped and i used it for a while just bolted together. Now i finally got the time to fix it. i was able to remove the broken spindle and the plan is to use just 1 inch bolt as pivot. Should i use grade 5 or grade 8 bolt? As of now, I am thinking 5 is enough and better - the green bolt from TSC.
Opinions?
I am not starting any grade 5 vs grade 8 flamewar, please:)
/ repairing landscape rake #2
Probably grade 5 would work, but I believe that you should go with the little extra cost and go with grade 8. The wear and stiffness factor in my thinking warrant it.
I built RB this past winter (I will be posting the process in the future) and I learned the hard way how much stress these things can take if we snag a corner. While the rake should create less stress than the blade there is still a measure of mechanical advantage. It is for these reasons that I believe that the center pin should be as strong as possible.
Mike
/ repairing landscape rake #3
I agree with Mike.
You might as well go with the grade 8 for the same reason you were thinking of going with the grade 5, except it's better yet.
/ repairing landscape rake #4
Mike
I completely agree 100%. I broke mine as well and rewelded it and a year later, it broke again. So, I machined a bigger pin and sleeve and no problems since to report. Here is my thread about my broken pin.
http://www.tractorbynet.com/forums/customization/79926-busted-landscaping-rake-rock-rake.html
My reasoning for 5 was, that the original spindle broke on shear pressure, apparently it was too brittle for this application.
I believe grade 5 will bent before it shears unlike grade 8 is going to shear before it bents. But I did my research:
Grade 8 vs Grade 5 - Pirate4x4.Com Bulletin Board
and your opinion counts too, of course:) and grade 8 it is gonna be:)
Thank you
Well, I got it fixed. Ain't really pretty, but it works and holds the load.
I had to cut out the old spindle with grinder, thats why the hole is square. I added and tackled one more nut in the middle of the bolt to have something to weld the top plate to.
/ repairing landscape rake #7
Looks great ... but I think it is time to invest in an oxy/acetylene torch! How much do you figure it cost you to make it in the first place? Would you do it again?
/ repairing landscape rake #8
Beauty is not so necessary as function. If it does the job it is a job well done!!:confused: :D
Mike
Tough question. I had some steel laying around from my trailer and tire carrier, the whole 3pt arm was made from it. I had to buy the angle iron for the rake and the tines of course.
Yes, I would do it again - but not with the trailer spindle:). I think i still put it together for less than half of what TSC sells rakes for.
/ repairing landscape rake #10
Thats what I wanted to hear! (I have been kicking around the idea of building one, but I am dreading drilling all those holes)
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
2014 John Deere 6105D (A64126)
2014 John Deere...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
LOAD OUT AND SHIPPING (A65579)
LOAD OUT AND...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
