Repair or Replace Grasshopper 618?
/ Repair or Replace Grasshopper 618? #11
You got a deal ae_ted. Those diesel kubota's are beasts.
/ Repair or Replace Grasshopper 618? #12
Froglick, I see you're from south central KY, so if you haven't jumped on something yet, you should be close to Barlows in Somerset. Maybe you could get into a diesel ZTR and not have to look back. I hear that Barlows is good to deal with.
/ Repair or Replace Grasshopper 618? #13
Ouch, those prices are outrageous. The prices I found were considerably less, they were doing it yourself or course. A shortblock is about $1500, A 20 HP Honda conversion is about $1500 and a 18 HP Briggs conversion will run about $1400. Any of these would allow you to keep the mower for considerably less than any of the figures mentioned before and the engine swaps are very straight forward Saturday projects. I have pulled the engine out of a Grasshopper 1622 and it was a very simple job to take out/put back in...maybe a 3-4 hr job with my teenage son lending a hand at times. The shortblock just requires your old heads, carb and muffler and is a little more work but still an easy weekend deal. Grass Hopper 618 Outdoor Power Equipment Repower from Small Engine Warehouse
I think a Command swap could be possible for much less too. The difference between the Triad crankshaft and the Command series is that the Triad 's shaft center sits 5.25" above the engine mounts and the Commands shaft center is 6.15". Grasshopper has obviously used the Command in other versions of the 618 mower and likely simply just used different motor mounts to account for the crank height and a 1" bore clutch ( this is just my speculation). The difference in crank shafts between the Triads 618's and Command 618 is yours has a 1 1/8 x 3 1/4" crank shaft. I guarantee if you are handy enough to fabricate engine mounts that are .9" lower and find any Command engine with a 1 1/8" x 3 1/4" crank, you can make it work....it may require simple electrical issues, muffler, etc and it takes work. It's also delving into "no mans land" and generally isn't for the squeamish. I probably shouldn't have even brought this up but I just went through a kind of similar experience with a John Deere zero turn and saved a ton of money on an engine swap I figured out.
/ Repair or Replace Grasshopper 618? #15
/ Repair or Replace Grasshopper 618? #16
Sorry man but I think you mean 1,000 hours, not 10,000!
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2008 CHEVROLET EXPRESS VAN (A60736)
2008 CHEVROLET...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
John Deere 568 Megawide Plus Round Hay Baler (A60462)
John Deere 568...
Giyi LS43 QA Log Splitter (A60463)
Giyi LS43 QA Log...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61307)
2021 Takeuchi...
