Repair manual 5740
   / Repair manual 5740 #21
Anyone have a 5740 montanna 2004 shop manual the clutch went out so I'd like to hear your offer on a shop manual you can email me.
   / Repair manual 5740 #23
If you'll go back through old threads on Montana, you'll find the contact info on the member who would e-mail one to you. I don't recall the name right now. I must assume that you've tried to adjust your clutch already through the adjustment behind the plastic panel on the left side of your dashboard, under the dashboard actually. I thought my clutch had gone out until the dealer showed me where the screw adjustment was under the steering wheel as I just described. BTW, I do have an original copy of the manual for the 5740C and for what it's worth, it reads like a comic book and like it was written by a drunk Korean! VERY poor printing job too. That's a fact!!
   / Repair manual 5740 #24
I have a 2007 or 2008 5740 never had any problem at all but now for some reason my shuttle eases out of foward but mostly when I am going down hill or on a slant to the driver side most every time anything might help ?
Thanks Reg
   / Repair manual 5740 #25
hey motorhomecpl, was wondering how you solved your shuttle issues on the 5740? Ours became so bad that you had to hold it in, any time the tractor was doing hard work. Had to take everything apart and now looking to replace Synchronizers and other pieces in the transmission. I just wanted to understand what is the source of the problem
   / Repair manual 5740 #26
Trying to resurrect this thread and ask if anyone can please forward me a Repair Manual for the Montana 5740. Your help is greatly appreciated.
   / Repair manual 5740 #27
Check here Index of /files. I also have a much better service manual that i can email to you.
Sent you an email incase you don't come back Do you still have the service manual for Montana 5740 on email. I need one. kisamore@outlook.com. Can you help?
   / Repair manual 5740 #28
I need a shop manual for 5740 Montana tractor
   / Repair manual 5740 #29
I need a shop manual for Montana 5740 tractor
   / Repair manual 5740 #30
Do you have facebook? I think theres some guys in the "Montana Tractors" who have a 5740 that bay be able to help. Search Montana Tractors.
   / Repair manual 5740 #31
The cab is designed to tilt back. If you notice there are back hinge points of the cab attached on top of the rear axle. Disconnect all the electrical plugs, there is no need to cut any wire at all. The AC lines have quick connects just above the fuel tank so there is no need to de pressure the AC system. Disconnect all the linkages, heater hoses and unbolt the front part of the cab leaving the back pivot points bolted. Get a lift or a few strong buds and tilt the cab towards the back of the tractor. This will open up the top area on the transmission where you can pull the inspection covers off and look down the transmission for your problems.
Hi Texasgreen want to see if the above description you gave to a new 5740 owner was for a 5740 or 5740C. If I am not forgetting what i read shortly after buying my 5740 the C stands for one with the cab, doors ect.
   / Repair manual 5740 #32
Hi I know it has been a few years since your post but did you manage to get hold of a 5740 repair manual? If you did would you share a copy with me? KY
   / Repair manual 5740 #34
Just joined and new to the forum. I've got a 5740 and having issues with clutch/transmission slipping (only 1050 hrs). First thought was clutch going out, but afraid it might be clutches in trans. Tractor will stop pulling but my PTO still works (maybe slows up a little, but it still turns bush hog). Any help in diagnosing my problem would be much obliged. I also would like to find a download for a service manual....Thanks, Bruce
i am experiencing clutch slippage and cannot adjust it anytmore. Did you ever have anyone reply to your post?
CATERPILLAR 336EL EXCAVATOR (A60429)
CATERPILLAR 336EL...
1605 (A57192)
1605 (A57192)
2020 DRAGON ESP...
2018 CSY (A59231)
2018 CSY (A59231)
UNUSED RAYTREE RMDB82-DIGGER HYD BACKHOE (A60432)
UNUSED RAYTREE...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
