Removing trees growing next to foundations.
   / Removing trees growing next to foundations. #22
It looks good the way it is....just cover it up, and mow off whatever shows up.
I plan to put a rack there for metal and pipe. The plan was to kill what I could prior to building it. Then control what came up. What you see is what I could not get.
   / Removing trees growing next to foundations. #24
Glyphosate, (Roundup), will do the same thing. After you cut the tree/bush just brush the chemical on the stump without any dilution for a complete kill.
I don't think I would do any more digging or pulling since it could damage the foundation. Just let nature do it's work and fill in the low spots later.
Roundup works and I just used it on some 6 inch stumps. Cut tree and within a couple minutes coat the cut with CONCENTRATED glyphosate--Roundup. Do it a couple more times but must be completed with 45 minutes of the initial cut. All trees I have ever done like this died. Don't dig near the foundation--lots of really bad and expensive things can happen.
POLY TOTE W/ WIRE CAGE (A58374)
POLY TOTE W/ WIRE...
Behringer 19 high x 43 wide Metal-Cutting Bandsaw (A59213)
Behringer 19 high...
FORD DEXTER TRACTOR (A52708)
FORD DEXTER...
2011 GMC Yukon XL Denali SUV (A56859)
2011 GMC Yukon XL...
60'' SKID STEER BUCKET (A56857)
60'' SKID STEER...
METAL BOLT BIN (A58374)
METAL BOLT BIN...
