Removing trees growing next to foundations.
   / Removing trees growing next to foundations. #22
It looks good the way it is....just cover it up, and mow off whatever shows up.
I plan to put a rack there for metal and pipe. The plan was to kill what I could prior to building it. Then control what came up. What you see is what I could not get.
   / Removing trees growing next to foundations. #24
Glyphosate, (Roundup), will do the same thing. After you cut the tree/bush just brush the chemical on the stump without any dilution for a complete kill.
I don't think I would do any more digging or pulling since it could damage the foundation. Just let nature do it's work and fill in the low spots later.
Roundup works and I just used it on some 6 inch stumps. Cut tree and within a couple minutes coat the cut with CONCENTRATED glyphosate--Roundup. Do it a couple more times but must be completed with 45 minutes of the initial cut. All trees I have ever done like this died. Don't dig near the foundation--lots of really bad and expensive things can happen.
1618 (A58375)
1618 (A58375)
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
New/Unused 2 Post Car Lift (A57453)
New/Unused 2 Post...
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
