Removing tc25d engine
   / Removing tc25d engine #1
Monday
New holland tc 25
I’m wondering if I have enough clearance to pull the engine without splitting the tractor? The front cross member looks close to the oil pan. Has anyone done it this way?
   / Removing tc25d engine #2
Pull the engine without splitting the tractor. It always seemed to me that pulling the engine IS splitting the tractor. Is this some sort of hypothetical question? Then I have to wonder WHY one would want to remove the engine without splitting the tractor?
Harry, splitting a tc25d would be removing the cab and steering column and cowl draining 5 gallons of hydraulic fluid disconnect hydraulic pump drain antifreeze and front drive shaft and loader the unbolt front frame. I was hoping for someone with actual experience in engine removal on a new holland tc25d instead of you folksy answer.
   / Removing tc25d engine #4
While it might be a "folksy answer" I can assure you that after having split a few hundred tractors and having removed multiple dozen engines for one reason or another, simply "lifting the engine out" is not an option. Most of the operations you described may well be involved, but it's all part of the package.
Having done this on many different makes and models, I can't recall one that required removing the cab.
Thank you for a real answer I appreciate it
   / Removing tc25d engine #6
Welcome to TBN!
It is an interesting question as some competitors mount their engine on mounts and it may be possible on those. The TC is designed in a traditional uniframe tractor design so, like @Harry in Ky said, it has to be split. Also, cab removal is not necessary.
Brent 320 Auger Wagon (A59814)
Brent 320 Auger...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A56436)
2023 Kubota...
2021 KUBOTA SVL75-2 SKID STEER (A60429)
2021 KUBOTA...
30ft Highway Trailer Co. Lowboy (A56436)
30ft Highway...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
