Removing rusty self tapping screws
/ Removing rusty self tapping screws #21
Seems to be lots of neat ways to do this job.:D
In the end probably one of the easier ways will be to saw the deck boards, pry them off, clean up stubs with an angle grinder, place new boards, drill new holes from the top, use proper sized bolts/nuts/washers and then use an air wrench to tighten.:)
If some boards are a little warped pipe clamps help get them in line.:D:D
Many of the original screws will break off when the cut board is lifted. Others will pull through the rotted decking board. A pry bar may be needed on some. :)
/ Removing rusty self tapping screws #22
Trying to save the existing holes is pointless.
locating, measuring then transferring this dimension to the new boards will take much time unless you can go under the deck and drill pilot holes with the boards in position.
I guess i dont see the benefit of all that extra labour, having done several in the home of excess road salt.:confused:
/ Removing rusty self tapping screws #23
I love me some stainles steel bolts, washers and locknuts. I would countersink the boltheads and washers with a spade bit after drilling the bolt holes. That's if I aimed to keep the trailer, and I do aim to keep the one I have. That's why I figure to do this job. Some of the rot is getting problematic. I replaced the hydraulic brakes when I got it. I'm old, so I hope whoever gets my stuff will see what they have there. I'm figuring treated wood too.
/ Removing rusty self tapping screws #24
Another thing you can do. Once the boards are removed, grind down the stubs, take a pin punch and drive the screws on out. Take some 6011 or 6010 and plug weld the holes, grind flush, place the new boards.
Thanks guys. I am going to try several different remedy's. If I can remove the screws intact, I will put down the same size boards, and drill a pilot hole from the bottom, and then install the new TORX screws.
I honesty did think the heat would break the rust grip. I have seen rusty bolts removed with two carbon arc rods to heat the rusty nut/bolt to a cherry red, and when cooled, they unscrewed. If I touched a single carbon rod to the screw, will the screw heat up or will something else heat up
I believe those screws are screwed into 1/4 steel. Do you think grinding and using a punch will work? I am also thinking that if I do punch them out, I will have to go to the next larger screw. They are self tapping.
/ Removing rusty self tapping screws #26
JJ - You've used a tap before, no doubt a million times. You know how they will jam up if you don't reverse the direction every half turn or so? That's the metal you cut getting jammed up in the tap. These things do the same deal as they tap their own threads going in. They are jammed up to beat the band, and I doubt will ever come out. And rusted. And Torx heads are really bad for shearing off the bits when you really pound on them with a breaker bar or impact wrench. DAMHIKT.
Go for the brute force method mentioned - cut the boards, pry them out and break off or grind/cut the stubs sticking up. The bottom is irrelevant so leave the stubs sticking out underneath. Then new boards, redrill and go.
/ Removing rusty self tapping screws #27
All the talk of screws has me wondering...I recently picked up a small 5x10 Carry-On trailer for small jobs.
The deck boards are NAILED on! I don't know what kind of nails they are but they are shot through the board and the steel angle cross members:eek:
I can't imagine the fun those will be when the time comes.....
BTW a local dealer sells the Carry-On brand for hundreds less than TSC or Lowes...:thumbsup:
Yes, you can use the Ramset to connect wood to metal. You need to test the metal by using one of the nails, and if it will ding the steel, it should penetrate. Thin stuff, not 3/8 in plate.
/ Removing rusty self tapping screws #30
I would forget about using the same holes.
1) You would probably need to drill holes in the new wood from underneath the trailer once the boards were on in order to have holes line up.
2) USUALLY you don't need half the holes that are OEM.
3) I usually make a channel in the front of the trailer bed to slide the front of the boards in so no bolts are needed. If nothing else just weld a piece of flat stock across the front of the trailer bed to make a channel.
4) Boards will last longer if loose and probably the steel will as well.
5) Depending on width of boards 2 bolts across the back per board.
Yeah I know this did not help much in getting out the old bolts.
/ Removing rusty self tapping screws #31
Bolts removed or not you can't hit the existing hole in the trailer with the new hole in the board. Give me a piece of machined steel finished all over and I can precisely lay out this piece of steel to match exactly the holes in the trailer. Give me a piece of wood that is slightly warped, off sized, and/or twisted and lay it out to match to perfectly matched pre-existing holes in the trailer just isn't going to happen.
/ Removing rusty self tapping screws #32
If it was me I would just get a couple of the .040 cut off wheels for a 4 1/2" grinder and cut through the wood and screws. Once the heads are cut then pop the boards off and put some penetrating oil on the screws and you may even be able to use the cut off wheel to cut the bottom of the screws flush with the steel. Then a day later you can try to grab the screw shaft with a set of vicegrips.
/ Removing rusty self tapping screws #33
J_J said if he could get the screws out, he would drill new holes in the wood, from underneath.
Granted that can be a viable option, but we aren't as young as we think we are, and laying on your back, drilling a hole two feet over your head, dodging chips from getting past your SAFETY GLASSES isn't going to be any fun, whereas if you drill new holes, you can pattern them for a better looking, more uniform trailer deck from above and not have to fight nearly as hard. Plus you can easily reach your glass of ice tea and actually be able to drink it without having to get out from under the trailer.
Drilling the wood through the old holes is going to rub the sides of the drill bit, making the hole even larger and probably out of round, so larger screws are going to required. More money for larger screws. If you don't want the old holes, weld them up, but I stand by my suggestion of not trying to reuse them.
David from jax
/ Removing rusty self tapping screws #34
...not to mention broken drill bits. I HATES breaking drill bits! :thumbdown:
/ Removing rusty self tapping screws #35
This is making too much sense to me. My trailer's deck is 14 feet long. I could see that channel at the front (mine already has it) and routing a couple of strips, one at seven feet, and one at the back end for that piece of flat stock. I could trust gravity and the load to take care of the rest. A little wood preservative where I routed the the reliefs and I would be secure in the thought that the design has been improved. When you think about it, the screws were put there mainly to hold the deck down. My trailer weighs 2,000 pounds empty. I don't think the deck is doing much in the way of structure, meaning all those screws are superfluous.
As far as the old self tappers are concerned, any way to get 'em gone is fine. The easier, the better. I'll be looking for the best way to keep the angle irons form rusting before I put the new deck on.
/ Removing rusty self tapping screws #36
Oh. I've done that many times. I seem to always get the bit jammed in the metal and break it.
I went through almost a whole set of 100 drill bits that came in a set for $100.00
I'm guilty of using the sides of the bit to cut a larger hole by twisting the drill back and forth, when I can't find a larger drill bit.
That's one of the most common causes for me "breaking drill bits" I know I really need to stop doing that. It's a habit I haven't broke yet.
Chad
/ Removing rusty self tapping screws #37
What you are trying to do sounds similar to tasks I've faced on car frames in the past. I take a 2lb mallet and give each screw a good pound to break the rust and then try to unscrew them. I didn't have a 100% success rate but it's quick and dirty.
/ Removing rusty self tapping screws #38
It seems that the thinner the steel stock you are drilling, the easier it is to break a bit, even bigger ones. When the bit finally cuts through, it may do only a partial hole and screw itself right in and catch you by surprise. Not only might the bit break, but it's likely to jerk the drill motor from your grip. I loaned a guy my 1/2" drill motor once, a big and very strong guy with arms like my legs. He was drilling a pretty large hole in some pretty thin material when the bit punched through and caught. In this case, he tore the pistol grip handle right from my drill motor. If it had been me, the grip would have slipped from my hands and come around and smacked me, or broken my wrist. That was even worse than breaking a drill bit.
/ Removing rusty self tapping screws #39
Ah, right on. That is the secret of pulling nails too. I've salvaged a lot of lumber from structures and learned that a long time ago (thanks to my late friend, Will Slayton). Step #1: give every nail a good whack. Then they come out like butter, instead of the heads breaking off.
/ Removing rusty self tapping screws #40
You piqued my curiosity JJ and since I have some carbon rods for my old school carbon arc torch ( which is very handy BTW...used it yesterday to heat some 3/4" round bar to bend at 90* angles) I thought I'd just see if your theory would work. I put some ( not sure if they are #5 or #6) 2 3/4" screws in a 2x4 and hit them with a Radnor 5/16" rod at various amps. I used 90,105 and 120 amps and the later had the best results. After 3-5 seconds this produced enough heat through the entire screw to scorch the wood on the side where the screw came through the board. It did catch the top of the board on fire pretty quickly but it was easily blown out with a strong breathe. I think your idea will work but it WILL produce fire.
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
2011 JAYCO TRAVEL TRAILER (A67714)
2011 JAYCO TRAVEL...
CAT 963D 4-in-1 Bucket (A68134)
CAT 963D 4-in-1...
X (A68191)
X (A68191)
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2013 BIG TEX T/A UTILITY TRAILER (A67714)
2013 BIG TEX T/A...
