Removing Kubota L4200 Stearing Cylinder
   / Removing Kubota L4200 Stearing Cylinder #1
jandreau
I'm trying to replace the large center steering pin and bushings in a Kubota L4200. I was looking for some advice on how to remove the pins that hold the steering piston in. I couldn't see anything holding them in.
   / Removing Kubota L4200 Stearing Cylinder #2
Looks like part #170 holds the pin in
#170 holds the center Pin in but I'm trying to remove the pin that holds the steering piston. It doesn't show that pin in the diagram.
I tried to take a picture of the top of the pin I cant see anything holding it but it won't budge.
   / Removing Kubota L4200 Stearing Cylinder #5
On the top there is a plate with 2 bolts take the bolts out and remove the plate part 200
Thank you. I never even see that pin in the diagram.
   / Removing Kubota L4200 Stearing Cylinder #7
What's the piston leaking
No, I have to get the steering arm out to replace the bushings but couldn't get it out until I unhook the steering piston.
   / Removing Kubota L4200 Stearing Cylinder #9
Did you get it apart ?
Not yet, the weather hasn't been very good the past few days. I'm hoping the weather tomorrow will be a little warmer to finish it.
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2- 30 X 42 TRIANGLE PIPE RACK (A52472)
2- 30 X 42...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
FAE 150/540 LOT NUMBER 137 (A53084)
FAE 150/540 LOT...
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
