Removing Kubota L4200 Stearing Cylinder
   / Removing Kubota L4200 Stearing Cylinder #1
jandreau
I'm trying to replace the large center steering pin and bushings in a Kubota L4200. I was looking for some advice on how to remove the pins that hold the steering piston in. I couldn't see anything holding them in.
   / Removing Kubota L4200 Stearing Cylinder #2
Looks like part #170 holds the pin in
#170 holds the center Pin in but I'm trying to remove the pin that holds the steering piston. It doesn't show that pin in the diagram.
I tried to take a picture of the top of the pin I cant see anything holding it but it won't budge.
   / Removing Kubota L4200 Stearing Cylinder #5
On the top there is a plate with 2 bolts take the bolts out and remove the plate part 200
Thank you. I never even see that pin in the diagram.
   / Removing Kubota L4200 Stearing Cylinder #7
What's the piston leaking
No, I have to get the steering arm out to replace the bushings but couldn't get it out until I unhook the steering piston.
   / Removing Kubota L4200 Stearing Cylinder #9
Did you get it apart ?
Not yet, the weather hasn't been very good the past few days. I'm hoping the weather tomorrow will be a little warmer to finish it.
2019 FORD TRANSIT CONNECT CARGO VAN (A52577)
2019 FORD TRANSIT...
2006 CHEVROLET EXPRESS SERVICE VAN (A52577)
2006 CHEVROLET...
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
