Removing Kubota L4200 Stearing Cylinder
   / Removing Kubota L4200 Stearing Cylinder #1
jandreau
I'm trying to replace the large center steering pin and bushings in a Kubota L4200. I was looking for some advice on how to remove the pins that hold the steering piston in. I couldn't see anything holding them in.
   / Removing Kubota L4200 Stearing Cylinder #2
Looks like part #170 holds the pin in
#170 holds the center Pin in but I'm trying to remove the pin that holds the steering piston. It doesn't show that pin in the diagram.
I tried to take a picture of the top of the pin I cant see anything holding it but it won't budge.
   / Removing Kubota L4200 Stearing Cylinder #5
On the top there is a plate with 2 bolts take the bolts out and remove the plate part 200
Thank you. I never even see that pin in the diagram.
   / Removing Kubota L4200 Stearing Cylinder #7
What's the piston leaking
No, I have to get the steering arm out to replace the bushings but couldn't get it out until I unhook the steering piston.
   / Removing Kubota L4200 Stearing Cylinder #9
Did you get it apart ?
Not yet, the weather hasn't been very good the past few days. I'm hoping the weather tomorrow will be a little warmer to finish it.
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
Chevrolet C8500 Flat Bed with a Moffet Kit (A53472)
Chevrolet C8500...
1985 Ford Ltl9000 Tender Truck (A53472)
1985 Ford Ltl9000...
2022 Wacker Neuson SM100 Mini Skid Steer (A53472)
2022 Wacker Neuson...
