Removing injectors Ford 3000
   / Removing injectors Ford 3000 #1
BobReeves
Platinum Member
Tulsa OK
Ford 3000
Can't seem to get the injectors free from the head on my 71 3000. Am pretty sure they have never been removed and seem to be stuck tight. Have tapped with a plastic hammer and pried with a 2 foot long screw driver like the manual shows but am afraid to get too forceful.
Any tips?
   / Removing injectors Ford 3000 #2
Hi try soaking with a good pentrene and leaving o/nite if that does not work some tool suppliers have small slide hammers that can screw onto or hook under the injector if this doesn't work you can try leaving the holdown nuts loose and run the engine hope you dont have to do what i had to last week and remove the head and use a drift to drive them out:mad: (last resort though) when you put them back in a coating of anti sieze helps you or the next person immensly. GOOD LUCK
Thanks,
Managed to get them out this morning. Used an aluminum rod and hammer to tap them around as far as they would go without removing the studs.. Back and forth a bit then a couple pry bars and they finally came out.
From the looks of the injectors it amazes me it would even run.
   / Removing injectors Ford 3000 #4
A testiment to that old iron...
soundguy
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2012 MACK PINNACLE (INOPERABLE) (A50854)
2012 MACK PINNACLE...
John Deere 960 Culitivator (A50514)
John Deere 960...
TEST YOUR BID BUTTON! (A51242)
TEST YOUR BID...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
