Removing injectors Ford 3000
   / Removing injectors Ford 3000 #1
BobReeves
Platinum Member
Tulsa OK
Ford 3000
Can't seem to get the injectors free from the head on my 71 3000. Am pretty sure they have never been removed and seem to be stuck tight. Have tapped with a plastic hammer and pried with a 2 foot long screw driver like the manual shows but am afraid to get too forceful.
Any tips?
   / Removing injectors Ford 3000 #2
Hi try soaking with a good pentrene and leaving o/nite if that does not work some tool suppliers have small slide hammers that can screw onto or hook under the injector if this doesn't work you can try leaving the holdown nuts loose and run the engine hope you dont have to do what i had to last week and remove the head and use a drift to drive them out:mad: (last resort though) when you put them back in a coating of anti sieze helps you or the next person immensly. GOOD LUCK
Thanks,
Managed to get them out this morning. Used an aluminum rod and hammer to tap them around as far as they would go without removing the studs.. Back and forth a bit then a couple pry bars and they finally came out.
From the looks of the injectors it amazes me it would even run.
   / Removing injectors Ford 3000 #4
A testiment to that old iron...
soundguy
2007 Peterbilt 378 Semi (A50514)
2007 Peterbilt 378...
John Deere 506 3 pt Mower (A50515)
John Deere 506 3...
1997 John Deere 8100 MFWD Tractor (A52128)
1997 John Deere...
2020 EZ-GO Elite RXV Golf Cart (A50324)
2020 EZ-GO Elite...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2015 CATERPILLAR 289D SKID STEER (A51242)
2015 CATERPILLAR...
