Removing high tensile fence wire to re-use?
   / Removing high tensile fence wire to re-use? #1
ShowroomShine
Raleigh NC
2019 Case IH 55A
I’ve got a 200’ section of fence with 5 strands I need to remove and I’d like to save the wire ideally. Just normal smooth high tensile wire, not barb wire.
What methods have you guys found to do this and save the wire or is it not worth it?
   / Removing high tensile fence wire to re-use? #2
The "old wire" around here is low grade iron with FLAT barbs. Dates back to the homestead days of the 1890's. It's not worth saving. But the farmers roll it up - I see rolls quite often on my neighbors property. Gets it out of the way and all in one place.
I also have smooth wire. It's telephone wire. Called CopperWeld. It's way beyond high tensile wire. Made to span 600 to 800 feet between telephone poles. The only way to deal with CopperWeld - cut into 10 to 15 foot chunks - throw into bonfire. The fire will soften the steel and it can then be rolled up. Then I dig a trench - at least four feet deep - bury the stuff.
Since I've not seen any "attachment" that has been used to roll up old barbed wire - I guess they roll it up by hand. This would be a REAL job. Some of the old barbed wire rolls are quite large.
I think before you go to all the effort to "save" - look into the future. What will you eventually use this smooth wire for and is it REALLY worth the effort to save it.
   / Removing high tensile fence wire to re-use? #3
I just took down 10 strands, 900 ft perimeter late summer around my mini-orchard/garden area that was mounted with electric fence insulators on wooden and t-posts. I built a wooden frame that I could stake to the ground with tent stakes and used some 3/4" cpvc as spindles to wind it up into spools. I kept a couple of spools and trashed the rest.
I used a piece of plywood for the base, 2x4s for 2 uprights with holes drilled up high for the cpvc spindle to slip thru. I drilled holes in the cpvc spindle to put a 1/4" bolt thru on the outside of the uprights to keep the spindle in place while cranking, I used flat washers to keep the bolt heads from digging into the 2x4s AND on the inside of the uprights to keep the wire from getting into the wood while winding. Out towards one end of the spindle I drilled a hole to put a short piece of 3/8" rebar to use as a handle to crank the spindle. When the spindle was full, I removed the bolts from the spindle and removed one of the uprights to get the loaded spindle out. Each spool holds probably 1/3 to 1/2 mile of wire in my case.
  • Good Post
Reactions: D&D
   / Removing high tensile fence wire to re-use? #4
Spinning Jenny will work, used wire spools will work. Worth it? Are you reusing or just recycling?
   / Removing high tensile fence wire to re-use? #5
With today's steel prices it's well worth saving it.
It will still have some memory to it and don't try to spoil it up as tight (small) as when new and you'll want a helper or 2. Making 10' (approximate length) loops and a couple of rolls of electric tape taping as necessary to keep it under control you'll wind it up in no time.
If you cut it loose from the new end point and leave it in the staples on the posts and make your coil at the "old" end will keep you from fighting the 200' wildcat that it will be just laying on the ground. 👍
   / Removing high tensile fence wire to re-use? #6
Have any photos of your nifty gizmo?
All the best, Peter
   / Removing high tensile fence wire to re-use? #7
This Spinning Jenny is what I use. Works best with my wife helping to keep a little back tension as I wind it up. Tye wrap the bundle and store it for reuse.
   / Removing high tensile fence wire to re-use? #8
A spinning Jenny is the answer. This is the best way to both install and remove high tensile wire. It’s how the professional fence people handle high tensile wire. You might be able to rent one, but they don’t look too expensive.
   / Removing high tensile fence wire to re-use? #9
All the best, Peter
I'll try to get a couple today (Tue). I have to use my camera and then put on the computer, no smart phones here.
   / Removing high tensile fence wire to re-use? #10
^^THIS^^
I've put up hundreds of miles of high tensile wire and I don't recommend messing with high tensile wire without a spinning jenny or a well made home fabbed version. Taking it down it easy, just wind it back onto the jenny. I use a plastic ring that drops over mine and then wind it outside of that so that it stays more of a round coil if that makes sense. When you take the wound up coil off place either 3-4 zip ties, twisted wire wraps or tape wraps on that coil so it doesn't fly apart.
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A59905)
2018 FREIGHTLINER...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
2005 MACK GRANITE CV713 DUMP TRUCK (A60430)
2005 MACK GRANITE...
