Removing Grease!
/ Removing Grease! #1
Jon E
Southwestern Vermont (on the NYS line)
2014 TYM T353HST
The former owner of my tractor must have decided that if a little grease was good, then a LOT of grease was better. This also appears to be the only preventive maintenance ever done on this machine. As a result, nearly every painted surface has globs and smears of black sticky (and now frozen) grease all over it. I have tried several things to remove it, including Orange Blast and other citrus cleaners, Simple Green, basic soap and water (Dawn detergent), and just picked up a bottle of Zep Fast 505 with hope that it might help. I am resigned to wiping every single surface off by hand with shop rags and degreaser. Is there a better way, or maybe a better solvent, or am I stuck degreasing my machine square inch by square inch?
/ Removing Grease! #2
I use Simple Green or WD-40.
Others use diesel fuel as solvent. I do not like to breathe that.
/ Removing Grease! #3
I am resigned to wiping every single surface off by hand with shop rags and degreaser. Is there a better way, or maybe a better solvent, ...
If the grease is dried out (lost it's lighter solvent components), probably not ...
Probably ...
/ Removing Grease! #4
just ditto'ing both folks comments above me. that ya in for a long haul.
a wire brush and a bowl of diesel, and getting messy (splatter every were) might work to get good amount of chunks off. granted scraping the paint off, and marking stuff up but... *shrugs*. make sure ya were eye protection, and a face mask. to keep from eating the stuff. and wear old rag cloths.
/ Removing Grease! #5
I use purple power on light grease but on big nasty stuff I rent a steam pressure washer.
/ Removing Grease! #6
Have you try WD40?
/ Removing Grease! #7
Gasoline!
/ Removing Grease! #8
One year, as a Christmas gift I got one of those little yellow Karcher electric pressure washers. I laughed and thought it was a toy...until I tried it. It cleans as well as the 13hp NorthStar pressure washer my dad used to have. Unbelievable power. The Vario nozzle really cuts through the grime. And they are cheap, like $150.
/ Removing Grease! #9
You could put your solvent of choice in a pump sprayer and spray it on, that's how we do it at work then hit it with a car wash brush and the hot water,the water from your hot water heater will work. Or take it to a cat wash if practical, they usually have decent degreasers and warm water
/ Removing Grease! #10
brake cleaner works great.I try to get it on sale at Autozone. It will remove the wax on everything so you have to rewax and regrease the areas that need grease.
/ Removing Grease! #12
Pressure washer and brake cleaner,
spray on the brake cleaner and use the pressure washer.
/ Removing Grease! #13
Oven cleaner when it gets warmer.
/ Removing Grease! #14
For the globs and build ups I use plastic putty knifes, but I would wait until it is warm...
/ Removing Grease! #15
One helpful tool is something like a wooden Popsicle stick, with the end cut square and beveled like a crude chisel... it will scrape well, but shouldn't hurt the paint underneath the crud. A spray bottle with a solvent is good, too. Hadn't thought of WD40, but it smells better than diesel.
/ Removing Grease! #16
I use a plastic putty knife and paper towels to get most of it off, power wash, then solvent (Purple Power is good) and towels for the final clean up. Then for maintenance I use a high quality grease (TRC Crown and Chassis moly), avoiding over application. The LockNLube grease gun attachment is great to ensure that the grease actually goes where it is supposed to. But a full clean up can take hours or days!
/ Removing Grease! #18
Bruce
/ Removing Grease! #19
I washed a cat once. He put up a good fight but I was more determined.
/ Removing Grease! #20
In addition to Purple Power, I've found that Klean Strip Liquid Sandpaper works very well. I've used it on a piece of equipment that the owner loved to over-grease. It does not remove paint, but gets it ready to repaint (a project for the Spring), so super-cleaning the paint now is not a concern to me.
Klean Strip | Easy Liquid Sander Deglosser
2004 JLG 944E-42 TELESCOPIC FORKLIFT (A64279)
2004 JLG 944E-42...
Sea-Doo Speedster Boat w S/A Trailer. (A61574)
Sea-Doo Speedster...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
1000 GALLON FUEL TANK (A64276)
1000 GALLON FUEL...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2020 Ford F-150...
(2) UNUSED 420/75R34 TIRES W/ 8 LUG RIMS (A64280)
(2) UNUSED...
