Removing ethanol from gasoline
/ Removing ethanol from gasoline #41
Thanks,but nothing even close to me.What gets me,is that they have to mix the ethanol in just before they deliver to the stations,so there is Real gas everywhere but they won't sell it.I would pay twice as much for some real gas!
No need, it is only about 40-45 cents more and is 90+ octane. I run it in my ecoboost when I tow. Too bad they don't make a 87 octane version too.
/ Removing ethanol from gasoline #42
The higher octane number the slower the gasoline burns. If you used high octane gas in old (pre-electronic) engines designed for lower octane gas you would burn the exhaust valves. New engines have sensors that adjust the advance for various gasoline so there is less danger to do so.
/ Removing ethanol from gasoline #43
Personal experience only... Since the ethanol gas was mandated, ALL of my small engine gas lines have crumbled. This includes the 18 year old weed wacker and the 3 year old weed wacker. Both the same brand. I'll assume using the same materials for the hose.
/ Removing ethanol from gasoline #44
Like a couple others here, I'm not swallowing the scare stories. E10 has been the norm here for more than a decade. Have about 10 different engines in various pieces of equipment. Never have had an issue. Never drain fuel over the winter, just use a little Sta-bil. Engines start normally the following season. If you're having issues, I'd look elsewhere. But that's just me.
Change of topics. Don't confuse octane with energy contend, they are NOT related. Ethanol has higher octane and lower energy content than straight gasoline. E10 has approx 3.5% less energy than straight gasoline. All else being equal, I find it hard to believe one can tell accurately and repeatedly reduced fuel mileage via seat of the pants "testing". There is more variability in driving conditions that is as equal as the 3.5% reduction in energy content.
YMMV.
Not to mention that compression ratios have gone up to compensate. Ethanol lowers power 3.5%, a bump in compression by 1 raises it back by 3.5% to 4%.. its a wash.
/ Removing ethanol from gasoline #45
I've been maintaining and repairing engines as a hobby for almost 40 years. E10 has been around for 22 years and it's the only fuel for the past 10 or so years. I've seen no evidence of E10 problems or any increased rate of failure. The brigs in my Bolens and the one in my little Viking snow blower are from the lead fuel days of the 70s. I have not touched the carbs in 20 years of E10 use and I have never drained fuel from either. I have never used stabil. All in all, I just can't imagine how our engines and fuel could be so much better than yours.
Every single time I broke down and tried Stabil, I screwed up the carb. I find its crap. I just leave the gas tanks near full and let them sit. Start up first time every time, even after sitting all winter.
/ Removing ethanol from gasoline #46
Ethanol I have been told is very bad for the rubber and plastic parts in the fuel systems on small engines like mowers. The 10% ethanol gas that I have been using in my truck for about 100,000 miles has not caused any problems.
That use to be, but once ethanol came in gas OEMs started changing to alcohol compatible parts.. Been 20+ years now for most OEMs.
/ Removing ethanol from gasoline #47
The 70's are long past sir. Starting in the late 80's when computers and feed back from O2 sensors plus lockup torque converters were used. The mileage of a current 300+HP 4x4 pickup is in the mid teens. In the 60's and 70's a 4x4 pickup did well to make half the mileage or HP.
While not 300hp, my '85 carb'd, non-computer, non-lockup D250 gets 13.5mpg..
/ Removing ethanol from gasoline #48
I wonder if its a location issue? I have pulled more water out of tanks and carb bowls then you could imagine. The climate in my area is from -20 to 110. Fuel lines if not silicone will break down internally like a eraser debris on paper.
Chris
In Indiana too and dont have that problem. I leave the gas in all season and off season. No probs yet.. Now, cheap @zz 'lawn mower' batteries on the other hand :rolleyes:
/ Removing ethanol from gasoline #49
Well, I have a 1996 Honda Goldwing motorcycle. Since we have been forced to use ethanol
laced gas, the carbs must be rebuilt each spring. Even after draining fuel from the tank and
the carbs. $800 every spring!:eek: The "rubber" parts dissolve. Echo pole chainsaw, gas lines
and pump totally rotted away. Husqvarna lawn mower, new carb last year, mower only 3 years old.
You won't ever convince me that ethanol fuel doesn't damage carbs. By the way, I worked as an International
Harvester mechanic all through college. So I have more than a little experience with engines and fuel
systems.
Bill
You are getting the wrong rubber parts.. Alcohol compatible parts have been around forever.
/ Removing ethanol from gasoline #50
I've heard of guy's buying aviation gas at the local (little) airstrip for their saws and other small sngines, been told that it's expensive, high octane and no corn in it, but local.
MoGas for planes is usually just alcohol free (E0) regular unleaded @ 87 octane, though there are some 91 octanes out there. If they are getting the 100LL, thats leaded gas.
/ Removing ethanol from gasoline #51
Here in southern Indiana an ethanol plant 90% complete was scrapped when this took place. The government still mandates its use. I think it is more expensive to make a gallon of ethanol vs a gallon of gas but could be wrong. Fortunately we have two local stations that sell pure gas for all my carbureted engines including my boat, motorcycles, two cycle equip., etc. I have cleaned out too many aluminum carbs and now just don't risk it.
Several never got built when the subsidies ending was announced. And it still takes more fuel to produce ethanol than you get out of it. Last I heard was 12 gallons to 1.
/ Removing ethanol from gasoline #52
Thats Backwards..
/ Removing ethanol from gasoline #53
I use marine grade stabil(purple color)or star-brite products.I had great success with both as far as removel of enthanol.coobie
/ Removing ethanol from gasoline #54
Where do I start? My ethanol woes are many, and varied. We used to get 48 mpg on my wife's Prius. Now we are lucky to get 42 or 43. My little truck went from 27mpg to 25. My two riding mowers, Lawn King and Husqvarna, both had all their gas lines just dissolve. They say the new gas lines are safe. Time will tell. I just trashed two push mowers and bought a new one. Carb jobs and new lines on both riders, a Johnsred chainsaw, old Solo weedeater, newer Troybilt weedeat with chainsaw trimmer. I'm sure when I go to use other things around the house that have sat for a while, there will be more added to the list. My handyman is a pretty good small engine mechanic. I have him on retainer.
I do use the Stabil products. I have found the newer one made for ethanol works better than the older mix.
Here in Bountstown Fl there is one place that sells pure gas. They are a bait shop, and sell gas for boaters mainly. But it is quite a bit higher priced. I just buy the other and add Stabil.
/ Removing ethanol from gasoline #55
Hi fellows
in canada high test gas does not have ethanol in it so just buy high test
you can easily test for ethanol
DEUTZ MARATHON...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
S/A Yard Dog Truck Tractor (A59230)
S/A Yard Dog Truck...
UNUSED IRANCH MINI EXCAVATOR QUICK COUPLER (A60432)
UNUSED IRANCH MINI...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
Kivel 48in. Forks and Frame Skid Steer Attachment (A59228)
Kivel 48in. Forks...
