removing engine cover BX23
/ removing engine cover BX23 #1
dkitch
kabota BX23
Any help is cool need to remove engine cover BX23
/ removing engine cover BX23 #2
Take the bolts out one by one. Yes, I am being a smart ***, but could you be a little more specific in what info you are looking for?
want to take the whole shroud off to drain and clean radiator and block. can not see any other way to get the bolt out of block and lower hose
/ removing engine cover BX23 #4
Don't you have a manual????
The shroud removal is way easier than the work you propose doing.
/ removing engine cover BX23 #5
On the front of the BX, where the hood hinges, you'll find two black plastic grips that you can loosen. Take them out, if you wish. They are design to be tightened by hand. I found if you closed the hood, ever so slightly, the surround pulled out the front easily.
BTW, if you have the front grill guard on, it is in the way, obviously. It will need to be removed first.
With the side curtain panels removed, the engine is exposed in all its glory.
/ removing engine cover BX23 #6
BP,
There should be a holder to keep the hood at 1/2 mast , it is kind of over the radiator.
Again it is in the manual:thumbsup:
Good directions for the 2 bolt task!!!!!!!!!!!!!!!!!:D
/ removing engine cover BX23 #7
If I recall, in addition to removing the grill guard, I had to raise the loader in order to pull the engine cover off...it's a pretty simple procedure. FWIW, I didcovered that I can remove the oil filter without taking the engine cove off.
/ removing engine cover BX23 #8
I've found that too although they could have made the filter slightly more accessable.
2017 BOBCAT E50 EXCAVATOR (A63276)
2017 BOBCAT E50...
Caterpillar 303.5E CR (A64126)
Caterpillar 303.5E...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
Landhonor Quick Attach Tree Puller (A66285)
Landhonor Quick...
2009 Kershaw 75-G2 Sky Trim (A65579)
2009 Kershaw 75-G2...
Great Plains 73290DH (A64126)
Great Plains...
