Backhoe Removing backhoe bushings
/ Removing backhoe bushings #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I found the swing pivot bushings on my Woods 9000 backhoe damaged when I pulled the main pins this past weekend. One is particulary trashed with a gap in the teflon (or whatever is in there) about a third of the way around. Can they be punched out (like motorcycle wheel bearings), or do they have to be pressed? Any good backyard methods of changing them?
Thanks - JayC
(btt)
Come on, SOMEBODY must've changed pin bushings at least once...
Thanx - JayC
/ Removing backhoe bushings #3
Jay4200 said:
(btt)
Thanx - JayC
Jay, I never have learned how to link to other threads but if you do a search for “Replacing hoe pins and bushings” you’ll find some ideas guys gave me. I’ve yet to do it myself so I don’t have any practical experience to share. Maybe the thread will give you some ideas.
MarkV
Thanks Mark -
I found your thread - it sounds like the bushings can be pressed out just like on a dirtbike. I'm no stranger to making pullers/pushers, but I've never done it for anything this big ;). If they can be pressed out with a threaded-rod puller, I'd wager that they could be tapped out with a punch too.
JayC
/ Removing backhoe bushings #5
Jay,
I was thinking about you making a home made puller. You just need a threaded rod (1" or so) and several larger washers, 1 steel plate with a hole in it and several nuts. The force from a threaded rod works really well for pulling stuck hardware.
Let me know if you get the bushing out.
Design.
2022 EZ-GO ELITE...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2022 EZ-GO ELITE...
5 SHANK V-RIPPER, 3PT (A64277)
5 SHANK V-RIPPER...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
