Remove water to add Rimguard?
   / Remove water to add Rimguard? #11
I have wheel weights and my tires filled but on a smaller tractor. I can not say I really notice that much more traction but it did add some stability. By the way I had 175# rear wheel weights first then put 4 30# front suit case weights on later then last year put in 20 gallons of Blue Windshield Washer Fluid in each of my rears for 40 gallons total or about 320#.
Chris
Diamondpilot - can i ask how you filled those tires? is there an adaptor - i was thinking i'd have to take mine to a dealer - i'm adding a FEL
GPintheMitten - thanks for the mold idea - i was working out in my head what i'd do for a mold - i've got some 3/4" X 8" steel rings with a 4" donut hole, basically giant washers i was going to do similiar to you - use the giant washers for the backside of the concrete weights, weld some tubing to for guides or bushings for the bolts to pass thru and weld in some rebar - but the mold was worrying me - i've got a ton of different size plastic buckets
tks
   / Remove water to add Rimguard? #12
tks
Gemplers.com carries the kits, got instructions too. Took my eye too. Didin't know about these :)
Dave.
   / Remove water to add Rimguard? #13
since that posting i'd actually thought about how to make or adaptor some metail valve stem caps to connect to a hose - i'll take a look at gemplers'
tks for the tip
My local dealer also sells them for around $10. You will need a fitting with a valve so that you can release the air pressure as you add the fluid. I did mine with one of those fitting and a garden hose. Just run the valve stem to the top and keep adding water and bleeding air occasionally until you get water coming out the valve stem. You can then set the air pressure on top of the water as needed. I think it is CRITICAL to be able to bleed the air off otherwise you have a very serious potential problem of overinflating the tire. You will also need to pick up a valve stem core remover if you don't have one.
   / Remove water to add Rimguard? #15
tks
Just to follow-up. I just got back in town last night after being gone for a few days. The bucket of concrete was good and hard. Spent a few hours getting them on the wheels. Hardest part is that they are so heavy. But I figured out an easy (relative speaking) way of mounting them. On my Kubota, the axles are hex, the wheel hub is hex and has a pin and bolt system that slides on the hex axle with various pinning points for whatever width you want to set the tires.
So I took the hubs off the axle but left them mounted to the wheels, set the whole tire/wheel assembly on top of the buckets with the threaded rod up. The wheels and tires were a lot lighter than the 80 pound wheel weights and easier to line up the threaded rod with the 3 holes in the wheel. Then I just tightened the nuts and mounted the wheel/hub assembly back on the axle. It was easier to line the hex up than 3 bolts. All done. Works great and looks good too.
Only funny thing is I used one green bucket and one white. I was going to paint them both black but forgot. I'll do that later.
If anyone wants to try this but can't quite visualize this, maybe I can get pics off my cell phone. Took some, but never have been able to get the pics loaded onto my computer yet. But hopefully, you can figure it out from the text I wrote up.
P.S. My wheels had 3 holes in the disc part of the rim, that's why I did the 3 bolts per wheel. Your wheels may be different. Anyway, for my little Kubota, that extra 160 pounds on the rear should help with traction this winter.
   / Remove water to add Rimguard? #16
tks
Sorry for the late reply. I used my valve I bought at Napa for about $15 and a buddies lawn sprayer with some hoses I rigged up. I have also used a 5 gallon bucket with a simple valve installed and a rope in a tree to hold it all. Gravity did all the work. I have also used a old Bilge Pump out of a boat in a bucket to pump it in.
Chris
   / Remove water to add Rimguard? #17
I'm also adding a FEL and need rear tires Juiced. I need some freeze protection but not a lot (North Texas/Southern Oklahoma). I understand how to get the water in but what痴 the best way to get the Antifreeze/Rim Guard/Wind shield fluid...... in the tires?
thanks, BH
   / Remove water to add Rimguard? #18
I filled mine with rimguard myself. I got the tool from NAPA and small pump from harborfreight (- Harbor Freight Tools - Quality Tools at the Lowest Prices). Picked up the rimguard in 55 gal drums and went to work. I figured out after a while that pushing the little button on the filler tool to release the pressure was taking way too long. So I would let the pump run for 5 minutes or so, stop and loosen the hose to release the pressure then start again. I think it took me about a little over an hour to get 50 gals in each tire. (16.9x30). I appreciated the fact the rimguard is not toxic, because one time it sprayed pretty good and I got a face full of fluid.
If you're going to add a rimguard water mix, just place both in a barrel and pump away. Or you can put the barrels on the back of the truck, forget the pump and let gravety do the work. Rimguard isn't the worst thing I've every tasted.
Wedge
Wedge
   / Remove water to add Rimguard? #19
thanks, BH
Same way you got the water in.
Wedge
   / Remove water to add Rimguard? #20
Rimgaurd is not used here if so very little. Mostly water and some antifreeze as freezing is not a major issue.
Local dealership has a portable air tank with a plug on it they fill with antifreeze and let the air push the antifreeze into the tire.
However I have used a funnel and let gravity fill mine of course before putting water in the tires and weight supported as below.
If you will jack up the rear tire you are filling and get all weight off of and them remove the core of the valve stem helps. In doing so my normal house water pressure is more than enough to fill the tire.
Now the question of tires spinning with ground engagement equipment: are you sure it is due to not enough weight? Not sure the specs but when weighted correctly they recommend a certain percentage of tire slip with disk or such. Yes you can get too much weight on a tractor which some here can do much better job telling of the excess wear to clutch and such it causes.
What type of tires do you have, loader tread or field tread. If the loader design it is my opinion you will never solve tire slippage with a disk, they just are not made for dirt.
Having said all that on my field tractor I run water/antifreeze filled rear tires with Kubota's cast iron rims and and about 300 lbs on front end weight. When I bought it had rims filled before it was delivered but the front weights helped to stabilize the front end.
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
2018 INTERNATIONAL 4300 NON CDL 26FT BOX TRUCK (A59904)
2018 INTERNATIONAL...
LEE BOY 8520B ASPHALT PAVER (A60429)
LEE BOY 8520B...
2005 GMC C7500 24FT BOX TRUCK (A59904)
2005 GMC C7500...
1997 WESTERN STAR DUMP TRUCK (A60430)
1997 WESTERN STAR...
