Remove the battery for storage?
/ Remove the battery for storage? #1
jtheise4
SE Michigan
Massey Ferguson 1643 & Allis-Chalmers D14
Just wanted to get people's take on removing the battery for winter storage. I have a JD X320 and this is the first winter I'll have it. Is it necessary to remove the battery or even just disconnect the leads?
/ Remove the battery for storage? #2
I never remove mine for storage. Have at least 6 different yard tractors and such with batteries, and in 40+ years have not found them not keeping well over winter storage. Some I run during the winter months, but some not. Occasionaly have to charge one up in the spring.
/ Remove the battery for storage? #3
How long is your winter, I used to put my tractor away in early Nov then hit it with the charger once a month. It was an 04 and when I traded it in this summer it was still on the factory battery.
The newX530 won't get off that easy as it will see plowing duty this year, it will have the leads on the battery to quick connect to the 1 amp battery tender when not in use.
/ Remove the battery for storage? #4
trickle charge it monthly, and you'll be great.
2018 Utility FS2CHA 48ft. 36 Ton T/A Flatbed Trailer (A61573)
2018 Utility...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
(2) 5' TRAILER RAMPS (A64280)
(2) 5' TRAILER...
APPROX (50)UNUSED CORRUGATED METAL SHEETS (A64281)
APPROX (50)UNUSED...
2015 KOMATSU PC360LC-11 EXCAVATOR (A64279)
2015 KOMATSU...
(2) BUCKETS OF GALVANIZED BOLTS (A64281)
(2) BUCKETS OF...
