Remove Latex Paint From Clothing
/ Remove Latex Paint From Clothing #1
dieselscout80
Elite Member
South Carolina
New Holland TC45DA
What’s the best way to get latex paint off of clothes?
I tried brush cleaner and Goo-be-gone and then washing them with no luck. They have NOT been ran through the dryer yet just line dried.
/ Remove Latex Paint From Clothing #2
Citrus paint stripper works pretty good
/ Remove Latex Paint From Clothing #3
Goo-be-gone, or caulk remover works pretty well.
/ Remove Latex Paint From Clothing #5
Subscribed to this thread. I have numerous pairs of jeans with white Latex paint spots. Never found anything yet that removes them. They do fade with time but always present.
  • Good Post
Reactions: JJT
/ Remove Latex Paint From Clothing #7
The pair of jeans I wear all the time. It's difficult to find the dried on paint blobs. I've used most everything to attempt removal. The final straw - heavy dose of Clorox. That did strip the indigo color out of one leg. So now - a pair of jeans with one blue leg - one white leg and a few dried on paint stains.
This all seems to blend well with the permanent grease stains and the Super Glue spots.
/ Remove Latex Paint From Clothing #9
Have you tried actual latex paint remover, or caulk remover?
DAP Caulk-Be-Gone Odorless Gel Caulk Remover 5.5 oz - Ace Hardware
I keep some around for the odd spot and I haven't had issues. I would check the label that the particular product is fabric compatible, as not all are.
All the best,
Peter
/ Remove Latex Paint From Clothing #10
For me those clothes with paint and grease spots are now dedicated work clothes. Go buy some new ones.
/ Remove Latex Paint From Clothing #11
Ya you got that right. Its not time or cost effective to try get the paint out.
For me its an almost new pair of jeans that I got paint on.
Other pairs I agree that they just become work clothing.
/ Remove Latex Paint From Clothing #15
I have plenty of clothes. I have 56 T-shirts. This collection began when the wife bought me a brand new Harley Davidson in 1998. Bought a new HD t-shirt every time we went to a new town with a HD dealership. Together the wife and I covered a lot of territory on the Harley.
I still have HD T-shirts that were purchased in 1998. Still in good shape. As you can guess. All I ever wear is T-shirts and jeans.
If the occasion requires a better set of duds - I'll be watching from the outside.
/ Remove Latex Paint From Clothing #17
I used to use isopropyl Alcohol for water based paint removal and MEK for oil based paint.
A lot of work (time) scrubbing with a toothbrush and rinsing.
Now I use the method posted by @mikester .
/ Remove Latex Paint From Clothing #18
Many years ago, I used to be able to get a hand cleaner called Cupran "New", it was an incredible laundry stain remover.
It would remove even dried automotive paints.
It's incredibly expensive now, if you can even find it.
The best practical way to remove dried latex paint is with denatured alcohol. But, most solvents like lacquer thinner, and Xylene, will also work.
You have to chose a way to keep it wet long enough to soften it all. But, in a few minutes it starts to work.
/ Remove Latex Paint From Clothing #19
I second the Xylene to soften all paints. for fun I gathered up several old paint brushes that I had found in bean cans I had forgotten about. A good soak over night and using a brush comb and they were back to life. You do have to wrap they in stiff paperboard to get the shape back.
For fabric, I would think you would need to place the fabric/spot on a pc of aluminum foil, soak spot with Xylene and cover with foil and place something heavy to seal it. add a bit more Xylene to keep moist. Then scrape the paint off. Rinse and repeat?
/ Remove Latex Paint From Clothing #20
Toluene works even better but both are bad for your gonads
