Buying Advice Remove cab door
/ Remove cab door #1
melgibson
Does anyone have any advice on how to remove the door on a 5600 D?
Thanks
/ Remove cab door #2
Did you get it removed?
/ Remove cab door #3
From what I read on a thread here, the person said to take the bolt out of the limiting strap and lift the door out of the hinges. Simple.
/ Remove cab door #4
Yep that's all there is to it. Took off mine to adjust door fit (wack on welded brackets on cab)
/ Remove cab door #5
Thanks for the update. Now I know how to remove a door in case I need to wack the brackets. :D
/ Remove cab door #6
Thanks
TCRanger here. Recently removed the passenger door to repair damaged door latch assembly. In addition to removing the screw on the strap, I had to lubricate the hinge pins, then lever/jack up the door as its a bit heavy to handle...a two man operation for us. It went back on easier than it came off though. Gravity is a wonderful thing when it works in your favor.
2023 Ford F-350 4x4 Flatbed Truck, VIN # 1FTRF3DM5PEC15665 (A61165)
2023 Ford F-350...
49"X79" WIRE MESH TAILGATE (A62130)
49"X79" WIRE MESH...
INOP/NON-RUNNING 2006 Freightliner M2 106 Day Cab Truck, VIN # 1FUBCXDC06HW03952 (A61165)
INOP/NON-RUNNING...
2023 John Deere 400R Spreader (A63109)
2023 John Deere...
UNUSED 44" HYD MINI ROCK GRAPPLE BUCKET (A62130)
UNUSED 44" HYD...
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
