Buying Advice Remove cab door
/ Remove cab door #1
melgibson
Does anyone have any advice on how to remove the door on a 5600 D?
Thanks
/ Remove cab door #2
Did you get it removed?
/ Remove cab door #3
From what I read on a thread here, the person said to take the bolt out of the limiting strap and lift the door out of the hinges. Simple.
/ Remove cab door #4
Yep that's all there is to it. Took off mine to adjust door fit (wack on welded brackets on cab)
/ Remove cab door #5
Thanks for the update. Now I know how to remove a door in case I need to wack the brackets. :D
/ Remove cab door #6
Thanks
TCRanger here. Recently removed the passenger door to repair damaged door latch assembly. In addition to removing the screw on the strap, I had to lubricate the hinge pins, then lever/jack up the door as its a bit heavy to handle...a two man operation for us. It went back on easier than it came off though. Gravity is a wonderful thing when it works in your favor.
1991 FREIGHTLINER FLA-89 T/A SLEEPER TRUCK TRACTOR (CABOVER) (A67148)
1991 FREIGHTLINER...
(10) UNUSED SDLANCH RS5007-2" RATCHET STRAPS (A65055)
(10) UNUSED...
213063 (A64276)
213063 (A64276)
2015 Chevrolet Tahoe SUV. (A64557)
2015 Chevrolet...
SPEC SPREADER 3PT HITCH (A64278)
SPEC SPREADER 3PT...
2013 Ford Escape SUV (A64557)
2013 Ford Escape...
