Remotes - Stupid Question maybe
/ Remotes - Stupid Question maybe #1
GPintheMitten
Elite Member
Flushing, Michigan
Kubota B2620 with BH65 backhoe, Ford 2N
So if I install remotes with Quick Disconnects and nothing connected to the disconnects, what happens if I move the lever? Can the disconnect take the pressure? Does the oil just go to return via the pressure relief on the valve?
/ Remotes - Stupid Question maybe #2
Yes that is what happens...the relief valve kicks in...
If you have a gauge you can connect it to an open QD and check the relief pressure...
Bush Hog 3008 (A64127)
New/ Unused Landhonor 2 Stage Air Compressor (A65583)
New/ Unused...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
2020 VOLVO VNL760 SLEEPER TRUCK (A59914)
2020 VOLVO VNL760...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
