Remote valve control reference
/ Remote valve control reference #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
/ Remote valve control reference #2
I don't see any specs listed ie. whats included, brand, etc.
/ Remote valve control reference #3
Anything wrong with this setup?
(B206305) Dual-Axis Remote Valve Control - Truck Equipment, Truck Bodies, Truck Accessories & Equipment Parts - Kaffenbarger Truck Equipment Ohio Cincinnati, Dayton, Columbus, New Carlisle, Sunnyvale Texas
Alternate suggestions or sources?
Seems like a good way to keep a compact open station free from hose clutter by placing the spool valve below the foot boards,
Control unit plus two cables for a bit over $100 seems worth while
If the valve you are going to use is a spool valve, this remote valve will add your $100 to the cost of the spool valve.
If the remote valve is solenoid, you only need wires to the dash or joystick.
The three spool DCV is made by Lamborghini. I'll be responsible for the cable connections at the valve.
Trying to end up with a install like this one. attached pic.
Three spool valve with a single dual valve remote actuator plus a single valve remote actuator.
2017 Ford F-450 Liftmoore 5000W 2 Ton Crane Service Truck (A61573)
2017 Ford F-450...
Caterpillar Engine Manuals Vol. 1, Vol. 2, and Vol. 3 (A63117)
Caterpillar Engine...
Grapple Mini Excavator Attachment (A61572)
Grapple Mini...
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
case 370 glass door never installed (A61307)
case 370 glass...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
