Remote valve control reference
/ Remote valve control reference #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
/ Remote valve control reference #2
I don't see any specs listed ie. whats included, brand, etc.
/ Remote valve control reference #3
Anything wrong with this setup?
(B206305) Dual-Axis Remote Valve Control - Truck Equipment, Truck Bodies, Truck Accessories & Equipment Parts - Kaffenbarger Truck Equipment Ohio Cincinnati, Dayton, Columbus, New Carlisle, Sunnyvale Texas
Alternate suggestions or sources?
Seems like a good way to keep a compact open station free from hose clutter by placing the spool valve below the foot boards,
Control unit plus two cables for a bit over $100 seems worth while
If the valve you are going to use is a spool valve, this remote valve will add your $100 to the cost of the spool valve.
If the remote valve is solenoid, you only need wires to the dash or joystick.
The three spool DCV is made by Lamborghini. I'll be responsible for the cable connections at the valve.
Trying to end up with a install like this one. attached pic.
Three spool valve with a single dual valve remote actuator plus a single valve remote actuator.
