Bob77064
Elite Member
Has anyone installed or had a remote start installed?
On my Truck
when the car is remote started, it shuts off when any door is opened. There was no way to 'program' around this.
i've never seen a remote that operated in this way, not syaing yours doesn't. that's a strange way to program the thing.
Then the person didn't properly evaluate the installer.I've installed about a dozen or so in past 10-12 years Fords, GM and Mazda, (Pro-Start Canadian Tire) never had a problem yet (knock on wood) Everyone says have a pro do it. I've seen two instances of 'pros' fail, the reason being is they use those cheap ***** scotchlock connectors for tapping into existing wires because they're fast. They cut thru a good portion of the wire you're tapping into causing resistance which in turn causes heat and so on.
