REMOTE HYDRAULICS ???
/ REMOTE HYDRAULICS ??? #1
steveky
Philpot, Ky
Kubota/ L3010HST, BX 1800
Anyone added any remotes to their tractor? I've got a L3010 hst with one remote and I'd like to add another. What about running off the FEL ports? I wouldn't be using the FEL as I'd be running a hay baler hyd tie from the FEL.
Is this a good ideal or not?
Thanks
/ REMOTE HYDRAULICS ??? #2
I have run my baler off my loader remotes on my New Holland TN. The remotes are the same they just have a joystick to control them instead of the lever. Just make sure if you leave the loader on you use the bucket curl remote so you can raise the loader still. Preferably you will just remove the loader completely and not have it bouncing around.
Do you change the fittings on the baler or is there a adaptor you can buy?
/ REMOTE HYDRAULICS ??? #4
What do you mean? Are your loader remotes different then the normal rear remote on your tractor? My tractors all have the same Pioneer style remotes so all I have to do is put the pioneer tips on my hydraulic hoses and I am set to go with any of my tractors.
I looked at it this morning, I'll just have to put females on my baler tie hoses as the loader has male fittings. It shouldn't be a problem at all.
Steve
2013 FORD F-350 SUPER DUTY (A65643)
2013 FORD F-350...
HD 24ft Free Standing Corral Panel with Feed Bunk (A65583)
HD 24ft Free...
2013 Vermeer Vactron Trailer (A64194)
2013 Vermeer...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
Skid Steer Deluxe Hitch Plate (A65640)
Skid Steer Deluxe...
2021 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
